Somebody please help me
Old Aug 20, 2009 | 01:52 PM
Twitch's Avatar
So my ignition locked up the other night and the key was stuck in the position right before you turn to crank it so i had constant ignition power flowing for a few hours and when i got it all fixed i charged up the battery and tryed to start it but no spark at all.Im guessing i fried something letting that constant power hit for so long because it was running perfectly before hand.Any one have any advice on what could of happened?
________
Prilosec Problems
Old Aug 20, 2009 | 01:58 PM
PurePontiacKid's Avatar
i felld offa mai trike
have you checked your fuses/fusible links?
Old Aug 20, 2009 | 02:20 PM
Twitch's Avatar
how do i tell if the links are bad.are they visibly burnt up?
________
SexualExtacy
Old Aug 20, 2009 | 02:47 PM
njgheewala's Avatar
Dunkin' Donutz
Not sure but could be possible to burn the coil like that???did you check the ignition coil?
The 'ON' position that you speak of is where your ignition sets all the time the car is running. That in itself should not have hurt your car, just drained the battery.
Old Aug 20, 2009 | 05:46 PM
Twitch's Avatar
Well it definately drained my battery but now i have no spark so something happened.what can i do to test the different parts of my ignition to figure it out.could the fact the key got stuck mean something in my ignition switch is bad and thats why it wont start
Old Aug 20, 2009 | 06:02 PM
Jasondiz's Avatar
You say you have no spark, but i just want to clarify its turning over right??
Old Aug 20, 2009 | 07:32 PM
Twitch's Avatar
Yeah it turns over fine but thats all it does it doesnt even start to sound like its gonna fire up at all.I also put a crane cams optical ignition module on it so any chance it could of fried?
________
LovelyWendie
Old Aug 20, 2009 | 08:06 PM
Yzzerdd's Avatar
Have your battery tested, or, if it's a manual, see if it'll push start. I have an 82 280ZX and periodically I would have to push-start it. The motor turned over fairly quick, but it wouldn't start. I had the battery tested, and it only had 80 cranking amps. The battery that was in it was supposed to put out about 800 cranking amps. New battery and presto! Starts instantly every time.
The only way I ever got it to start with the old battery, other than pushing, was jumping it off my mom's Expedition. It had a big battery and a big engine. Now that I think of it, I did start it off a Ford Ranger, but the guy had to keep the motor at a fairly high rev before the car started.
--Ryan
Old Aug 22, 2009 | 11:05 PM
Twitch's Avatar
Well my batteries fine i tested it and used my friends brand new battery he had just got for his jeep and still nothing at all.Any suggestion anyone?
________
Uggs
Old Aug 23, 2009 | 01:44 AM
If you have no spark, then why dont you take a volt meter and see if the coil is getting power, if its getting power then test your ignition module..etc
Old Sep 4, 2009 | 10:32 PM
Twitch's Avatar
Well my z is running great again turns out my coil and main voltage wire were both fried so put a blaster 2 coil and new wires and fired right up
________
Johnny claes
