solid engine mounts?
Old Sep 30, 2004 | 06:34 AM
roninjiro's Avatar
Cool
i took off my engine mounts and all who know what they look like guess what i did? i burned off all the rubber and closed the gap then welded it stiff. But there was a HUGE complication! i didnt measure how high the mount shoud have been (rubber mounts compress alot.....). so come to find out with motor down and all; i am 4 1/2 inches above the rack and pinon. you may think its not huge but that is extremely high. so off to the welding shop again. this time i measured the height i wanted, mabe a 1/4 inch above the rack, so this mount is really slim. btw anyone have solid engine mounts???? or experienced it?
Old Oct 1, 2004 | 09:08 PM
roninjiro's Avatar
Talking
just got the mounts redone and now it is a 1/2 inch too low (engine lays on rack) so the easiest solution and quickest is to add washers to raise the mounts 1/2"....
top pic is sideways, so bear with me....
also i still have to trim the excess plate off.
Old Oct 2, 2004 | 12:32 AM
Las VegaZ's Avatar
Why would you burn the rubber off and switch to solid mounts? Do these motors really move that much?
Old Oct 2, 2004 | 12:52 PM
roninjiro's Avatar
my mounts were flaking apart for some odd reason, so i have to replace them anyway. i just wanna feel how hard the car will vibrate
Old Oct 4, 2004 | 09:07 AM
If you can do that much fab work, why not custom fit the radiator up front? It'll look better and cool the engine much better. Start hacking!
Old Oct 7, 2004 | 04:12 PM
roninjiro's Avatar
Talking
no doubt, i will indeed start hacking, i just am worried about the structural integrity if i cut into the frame, does anyone have any ideas
Old Oct 9, 2004 | 10:41 AM
BJ BISIG's Avatar
Lots-o-vibration
I HAD A '50' CHEVY, SB WITH A SOLID LIFTER CAM. YOU'LL TEND TO GET A LOT OF VIBRATION -ENGINE NOISE THROUGH THE FRAME. A GOOD UPGRADE FROM RUBBER WOULD BE URETHANE MOUNTS. JUST MY $.02.
GOOD LUCK, BJ
Old Oct 9, 2004 | 05:25 PM
anlasak's Avatar
You could also make your own urethane mounts out of 3m window weld.
Runs about $15.00 a tube and 1 tube will do 2 motor mounts and about half a transmission mount.
I've used the stuff on my B13,S130,and my S13 and like it better than oem or solid mounts.
The stuff takes about 3 days to cure,its a lot stiffer than the stock rubber ones and you only get a little excessive vibration over the "I think I need dental work" solid mounting method.
Old Oct 10, 2004 | 06:20 AM
roninjiro's Avatar
where do you get the urethane in a tube???
Old Oct 10, 2004 | 08:11 AM
anlasak's Avatar
I found mine at carquest. The 3m part number is 0 51135-08609.
Just in case you don't have a carquest near you 3m's number is 800-364-3577.
Word to the wise,make sure you wear some gloves,it takes about a week to get the stuff off your skin.
zachary.ard
FS: 300ZX (84-89)
Jul 29, 2011 06:44 AM
BlueKitsune
Jul 7, 2009 10:41 PM
DropTopTwin
Apr 26, 2009 04:41 PM
91zxtt
Aug 3, 2004 12:41 PM
preith
Jan 5, 2004 01:40 PM
