1983 Turbo Dist. to 1981 Turbo
Old 01-14-2018, 11:23 AM
kraztrini's Avatar
A Happy New Year to all. I have a question for the experts here. I am planning on switching the Distributor from an '83 Turbo to an '81 Turbo. I know their is a Post on ZDriver about doing this but will the '81 Turbo ECU recognise the '83 Turbo Distributor. Thanks.
kraztrini is offline
Old 01-14-2018, 06:49 PM
Yes indeed.
See: https://www.zdriver.com/forums/280zx...-timing-40948/
*Note: The 81 280ZX Turbo distributor does not have an internal CAS, using instead a plate attached to the back of the crank pulley and magnetic sensor mounted on the A/C bracket. Both output the same signal, but the advantage to the 82-83T optical CAS is ease of changing the encoder disc for various EFI setups, and ease of timing adjustment.
NismoPick is offline
JaYaYsSoHN
10-28-2018 06:10 AM
RunninOnEmpty
09-06-2003 12:02 PM
speedgato
07-29-2002 09:36 PM
skywagoner
03-28-2002 12:10 PM
skywagoner
03-25-2002 10:10 PM
Quick Reply: 1983 Turbo Dist. to 1981 Turbo
