seems to die on top end
Old Jul 21, 2003 | 07:33 AM
TX_zx's Avatar
my guess would be your dizzy is giving up. electronic ignitions are known for giving up at top end. Might try recurving it, there isnt much instructions, more like trial and error
Old Jul 21, 2003 | 03:28 PM
veyenyl's Avatar
I am having the same problem. I took it to the track and it felt like I hit a rev limiter in third when I got close to 5000 rpm. I ran a 15.1 @ only 85 mph boosting 10psi. Never got out of third gear. I guessing it's fuel related. My fuel pump may not be supplying enough fuel at that load. I'm gonna try hard wiring the fuel pump with 10ga wire and a relay to see if it helps any. Haven't checked my base fuel pressure yet either.
I running stock 83 l28et, stock efi with a mkIII supra ic in a '71 240.
Old Jul 23, 2003 | 07:35 PM
lifegrddude's Avatar
Externally Wastegated
You might wanna check your AFM out, it's happened to me before. That and the plug wires were fried. I couldn't get past 5400 revs without the car sucking wind. Stock my car ran 15.3 at 89 so yeah I'd think if it's not the AFM, then check the injectors to see if they're flowing enough and not dying out.
John 82ZXT
