ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   Rusted and bent jack lift points (https://www.zdriver.com/forums/280zx-s130-forums-77/rusted-bent-jack-lift-points-22341/)
iluvJDM Mar 30, 2007 12:23 PM
Hey guys, so i go to jack up my car the other day when i realized the points where u put the jack and lift the car have now rusted to hell. They were already bent when i bought the car 4 years ago(where the front fenders bolt, yeah i cant remove my fenders either since the its all bent out of shape where the bolts are) Anyway I really wanted to do my oil change so i tried jacking up from a point near where it was bent and rusted and it just bent as well, What can i do? Also LMK if you need me to post pics...its not pretty though:paranoid:
SportBikeMike Mar 30, 2007 12:59 PM
Buy ramps!
iluvJDM Mar 30, 2007 01:03 PM
Buy ramps!
not a bad idea...but i dont have room :(
icice9 Mar 30, 2007 01:57 PM
if your going to jack the car up the best place to do it is on the front cross member (not the radiator support) those jack points were intended for your tire jack and not your floor jack...
WildmaN Mar 30, 2007 02:18 PM
Yes do what iceice9 said, and use the front crossmember, then put the jackstands, right under the control arms. That is where I usually put mine. Good luck to you bro'
thxone Mar 30, 2007 03:17 PM
Buy ramps!
LOL :044: Have you ever tried to drive a 280zx up on ramps? Backing the rear up the ramps usually goes ok but the front is far too low...unless you don't mind pushing the ramps down the street.
iluvJDM Mar 30, 2007 04:31 PM
ahh...yeah my uncle said use the crossmember too, glad to have found a solution:) im about to start my turbo install in the coming weeks and i started to panic when i realized the rust, one thing though...my car is lowered how do you guys slip your floor jacks under the car to the crossmember?
thxone Mar 30, 2007 04:55 PM
I put mine under the lower A arms. I also use Jack Stands
SportBikeMike Mar 30, 2007 05:04 PM
I got a lowered 350Z with a bodykit on ramps no problem. Theres lower profile ramps available.
icice9 Mar 30, 2007 06:07 PM
use 2 2x4 or 2 bricks.. put the 2x4s in front of the front tire and drive the car over it.. it should raise the car high enough to get the floor jack under the cross member.. my car is lowered too and thats the method i use..
entropy31 Mar 30, 2007 06:09 PM
i use 2x4s for my z32. super hi-tec :D.
thxone Mar 30, 2007 06:24 PM
They make low profile car jacks....for low cars............whoever "they" are.....crap now I am kinda sacred :paranoid:
Heat Rave R Mar 31, 2007 12:21 AM
I have a lowered 280ZX and I have no problem getting up those plain black Rhino Ramps. Admittedly, I have no aftermarket front bumper (those make it harder to clear) and I just barely get up on em.
