roll cage from 77 into 79?
Guest
Posts: n/a
will a roll cage from a 77 fit in a 79? i have this roll cage we pulled from a 77 its car and i wanted to put it in mine. ive noticed if you order a roll cage from a z supplier, they use the same part number for 70-83. thanks
SoCalZ Prez
http://www.socalz.org
SoCalZ Prez
Re: roll cage from 77 into 79?
I'm not sure if it will work because aren't zx's slightly wider and longer than z's? You should try and contact either Autopower or Dave Turner Motorsports. If you run a search engine you should find the websites. Good luck.
82 ZXT
82 ZXT
