Rear Strut Posts
Old Jan 5, 2004 | 11:38 AM
Carl's Z's Avatar
Rear Strut Posts
Ok, I just replaced my rear struts, and here's my question:
On the center post at the top, where the single nut is holding the top onto the coil (just under the tower cap), is there a measurement that is normal for that nut to be down from the top? My thought is that the closer the nut is to the top, the higher the rear will be (kind of). It's hard to explain, but I'm sure someone out there knows what I mean, right
Thanks...
Carl
Old Jan 7, 2004 | 02:58 PM
Carl's Z's Avatar
See, that's the thing. I'm not really sure where they were, and I'm not sure if the previous owner knew anything anyway. It just seems to me that when you tighten that nut, that your compessing the spring at the same time. I may be wrong, but from what I can see, that seems to be the way it is. And if that's the case, then why not leave it as "loose" as possible (while everything seems tight anyway), and put a second nut on it to keep the first nut on and gain the height (whatever height can be gained)?!
This just seems logical to me...
iluvJDM
Jul 23, 2008 07:09 PM
waterdogzx
Apr 21, 2005 08:22 PM
Carl's Z
14
Jan 9, 2004 12:03 PM
tsefreeflow
Oct 23, 2002 08:03 PM
zxturbo
Oct 21, 2002 11:02 AM
