Rain leaking in! Any way to adjust door windows?
Old Apr 5, 2005 | 08:17 PM
Heat Rave R's Avatar
I have an '82 280ZX with t-tops. However, it isn't the t-tops that's really causing my leaking problem. I got brand new, official Nissan weatherstripping for the doors and on the driver's side body. And yet, I'm still leaking. Water seeps in between the door window and the weatherstripping. It's almost as though the window doesn't roll up far enough to create a strong seal. The doors seem aligned with the body, so I don't think it's the doors themselves as being the problem. Strangely enough, I don't have the same issue with my rusty, beater '83 t-top turbo. So does anyone know if it's possibly to make adjustments to how high the door windows roll up? Another millimeter or 2 higher might solve my problem, unless someone else has a good solution.
Old Apr 5, 2005 | 10:05 PM
Fast240Z's Avatar
I'm not sure if there is a way to bring the window up, but you could try getting out of the car, rolling the window up, and then physically grabbing the window and trying to pull it up farther.
Old Apr 5, 2005 | 10:47 PM
apollo's Avatar
Pro Pumpkin Carver
yea, im pretty sure you can, if you open up the door, look for the little round stoppers on the glass. i belive those are ajustable, and should be able to fix that, but i may be wrong
Old Apr 6, 2005 | 11:15 AM
apollo's Avatar
Pro Pumpkin Carver
actually i think what icice had shown me was that the rail adjustments might help with that. if you look for the 4 securing bolts for the window rails, losen the nut, then turn the bolt itself to adjust the window. i had water coming in between the window and the outerwindow seal that runs along the lower part of the door. when i adjusted it it believe it made a stronger seal against the top rubber as well because now i have no wind noise as well.
Old Apr 6, 2005 | 04:57 PM
Whoa, alarmingly, I found a puddle of water in my spare tire well too! Once again, my rusty beater ZX doesn't leak like my "good" one! And I really have no clue where this water is coming from since the surrounding area appears to be dry (though it has been a couple days since the last rain).
Old Apr 7, 2005 | 12:23 PM
apollo's Avatar
Pro Pumpkin Carver
rear right tail light for me, i had to put that windshield "ribon" around it to prevent that from happening as well. dont you just love old rubber that leaks?!?!?
Old Apr 7, 2005 | 09:00 PM
Hm, I dunno if it could be the taillight that's leaking for me. If it were, I would've thought water would've pooled up on the trunk floor, not just the spare tire well. I sure how to god that it's not the rear window itself that's leaking.
Old Apr 7, 2005 | 09:18 PM
apollo's Avatar
Pro Pumpkin Carver
well see, i think in my case what happend was that water runs down the hatch seems and the gaskets leaked. and since int eh trunk area there is a lip around it it ither ends up in the spare tire well or in the other side.
Old Apr 7, 2005 | 09:28 PM
Skully's Avatar
same for me it runs down the outside of the hatch...inbetween the black plastic cover of the tailight and the metal frame and into the wheel well and into the trunk area too....when my car was outside and iw as working on it i didnt have a cover so i just ductaped the gap, worked fine hehe...
LVZ280
Jul 8, 2011 07:28 PM
dhp123166
Jan 25, 2010 06:07 AM
tonsoffun300zx
Dec 12, 2007 08:25 AM
RodMoyes
Feb 14, 2007 06:51 PM
n_2_fairladyz
Apr 14, 2005 09:54 AM
