Quick Question
Old Feb 11, 2008 | 08:10 PM
krakerjak's Avatar
Quick Question
Is there any way to make a Newer Altima's Cluster work with a 280zx or is that just not posible?
Old Feb 11, 2008 | 08:23 PM
ANYTHING is possible... the limiting factors are time & money.
Is it realistic? Not at all. Why do you ask?
Old Feb 11, 2008 | 09:03 PM
why do you care?
Old Feb 11, 2008 | 09:39 PM
krakerjak's Avatar
my friend has one and i wanted to put it ito mine since it looks nicer, so you say there is no way possible huh?
Old Feb 11, 2008 | 09:55 PM
It is possible... NOT REALISTIC. You'd prolly spend several hundred dollars and countless hours trying to figure it out.
Originally Posted by hoov100
why do you care?
He asked for a reason... trying to find out why. Duh!
Old Feb 11, 2008 | 10:11 PM
meh, i wouldnt do or not do something because others tell me its not worth it....
(has nothing to do with anything.)
(yes i just said that)
(need mo' beer!!!!)
Old Feb 12, 2008 | 10:02 AM
FubarI33t's Avatar
Now a S30 dash in a S130 is possible. And they are just the best damn lookin dashes I've ever seen. Plus if you want aftermartket tachs and speedo's are the same size as factory. Just swap em. Same for the smaller ones. The S30 dash is 1 inch shorter then a S130 dash. Come on .any idiot ca fill a half inch on both sides.
Old Feb 12, 2008 | 12:36 PM
Put the whole dash and interrior from the Altima in your Z.
L-series components and design are somewhat simular to the KA series... just a while guess but it may not be as hard as you might think. you'd have to hook up the Altima dash wiring harness, power it somehow, and then individually figure out where to get your signal from for each gauge. Certainly not a bolt-in swap if that's what you're after.
Now... the tachometer is factory made for a 4-cyl and your Z is a 6. There lies your first problem.
Old Feb 12, 2008 | 04:58 PM
krakerjak's Avatar
it's a 3.5 altima so it's a 6 cyl and what my best guess is you have to splice a few wiring making sure which ones on a wiring diagram , I don;t think this would be very expensive unless i would need the whole dash wiring harness?
But do the speed sensors and the Rpm sensor go through the Ecu thats the oly question i have, other then that it would be a fun weekend
Old Feb 12, 2008 | 07:39 PM
OH, I assumed 1st gen for some reason... not even a KA24 in the 4-cyl.
ya, that is going to be much more difficult.
z31Nightshift
Jul 26, 2013 06:14 PM
skittle
May 20, 2008 08:46 PM
duowing
May 30, 2007 05:17 PM
bradyg
Apr 13, 2006 05:36 AM
saaddaa7
Aug 8, 2003 09:17 AM
