question about JSK fuel rail
Old Jan 26, 2006 | 03:37 AM
Hey everybody, I am wondering what I need to put on the fittings on my JSK fuel rail. As where, I don't have any fuel leaks and such. I am just getting a rough idea, and preparing myself. When I get my motor back in, and start hooking things back up. So anyway any input, and or advice you could give me. Would be much appreciated, and thanks.
I pretty much have an idea, on how I am going to mount it. After eliminating the original trombone and such. I just want to make sure, I don't have any surprises, when I get my Z running here soon. Hopefully this weekend, but if not. Definately the next one coming up.
Old Jan 26, 2006 | 07:08 AM
AutoZone has a couple different thread sealers. I think I used one by RTV (comes in a white tube). Whatever you get, just make sure it says it will withstand contact w/ fuel.
Old Jan 26, 2006 | 08:57 AM
Get in the zone
Old Jan 26, 2006 | 08:58 AM
Originally Posted by Bleach
Get in the zone
LoL... AutoClone!
Old Jan 26, 2006 | 07:09 PM
jmmorriso's Avatar
If you want to get technical, You do not need to seal a pipe thread joint. Pipe threads are an interference fit, the angle of taper is greater on the male end than on the female to a very small amount. Teflon tape, and the white stuff are basically lubricants to allow you to screw the fitting together enough to make it seal, Rectorseal, is a sealant and is used mainly on natural gas lines. It bonds to skin right away and takes a helluva lot of scrubbing to get off. Hey, you ever take a pipe fitting apart right after assembling it and notice that almost all of the teflon tape has dissappeared? WTF?
Old Jan 27, 2006 | 12:40 AM
Heat Rave R's Avatar
I just got me an aftermarket fuel rail too. The thing I'm concerned about is the size of the rubber hoses that I would need to run from the filter to the rail, and from the rail to the metal return line. I always thought the stock rubber hose lines were some odd size like 5/16", while the aftermarket fuel rail fittings were intended for 3/8". If that's the case, then I wouldn't be able to run 3/8" hose to the fuel filter or metal return line fitting without having sealing issues. Has anyone dealt with this part before?
Old Jan 27, 2006 | 08:15 AM
If that is the case, then you buy 5/16" hose and stretch it that extra 16th of an inch over the fuel rail fitting. That's only a 32nd of an inch more on each side. Rubber hoses are suppose to be soft. With the barbed fitting, it would probably seal fine even without a hose clamp. (but I'm using clamps)
Old Jan 27, 2006 | 08:20 PM
jmmorriso's Avatar
Dont all the fittings screw into the fuel rail? You should be able to get 3/8 pipe to 5/16 barb fittings at a hardware store, or if you want to get fancy go to Vic Hubbard in Hayward, and they can get you stainless steel ones, im pretty sure.
Cingularity
Oct 26, 2013 08:42 AM
MurphyEF
Oct 4, 2012 08:24 PM
BigBirdsZ
Nov 11, 2006 09:44 PM
007max
Nov 7, 2006 10:19 AM
brad101010
Mar 17, 2006 09:41 AM
