ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   pressure relief valve (POV) popping??? need help!?! (https://www.zdriver.com/forums/280zx-s130-forums-77/pressure-relief-valve-pov-popping-need-help-32981/)
Hamer007 Jul 4, 2011 11:07 PM
ok so i was driving my 1983 280zx turbo and downshifted to speed up... and then all of a sudden sounded like tons of backfiring and stuff. i see the pressure relief valve next to the EGR is popping and backfiring out of airbox i think? i can get it started by pumping the gas.... then by hitting the accelerator i get the pop off valve going off and backfiring.
when i drive it i have nooooo power hardly when i hit the gas just popping noise's but when i hit the throttle slow it speeds up. OH and when i downshift no popping just rpms rev with no problems, so engine is fine :) thank goodness lol.
so i wonder what i screwed up. plz help :(
hoov100 Jul 5, 2011 01:10 AM
Have you tried doing a boost leak test?
Hamer007 Jul 5, 2011 01:40 AM
how do i perform that?
NismoPick Jul 5, 2011 08:56 AM
How do you see this? Are you driving w/ no hood, or are you revving it in park w/ the hood up?
Hamer007 Jul 5, 2011 01:07 PM
im reving it with my hand in nuetral, and listening to the engine...
NismoPick Jul 5, 2011 02:42 PM
So it's backfiring out the intake, which means it's running lean. I suggest checking your CHTS & AFM & connections. Also, I suggest pulling your spark plugs & reading the tips to see if one cylinder isn't firing.
Hamer007 Jul 5, 2011 03:06 PM
ok i will do this tonight and check back.. Thanks :)
FricFrac Jul 5, 2011 05:50 PM
I'm not sure if I want to know how you got your hand in neutral...
Hamer007 Jul 8, 2011 07:06 PM
me either :102:
Well i looked at the car and i cant find it out, i think im gonna have to sink in and go to a mechanic :(
Hamer007 Jul 8, 2011 07:18 PM
any more ideas before i take it in monday? i got fuel and compression is there.. so an air issue im assuming. sparks is there too. i just am stumped lol. Very hard to start it now.
Bleach Jul 9, 2011 10:20 AM
A small rubber hose may have come loose. Your air flow meter could be bad.
I do not think it is the POV on the intake manifold. That thing flutters when it releases air.
audiofreak97 Jul 11, 2011 01:17 PM
Did you double check your timing? The distributor could have moved...
Bleach Jul 11, 2011 03:02 PM
Is the parking brake on? :)
Hamer007 Jul 14, 2011 08:18 PM
I took it to the mechanic the other day, dont know what was up, but im thinking its a valve bent or stuck. Well see what he says :102:
duckyz Jul 14, 2011 09:04 PM
When was the last time you replaced the fuel filter?
Hamer007 Jul 16, 2011 01:16 AM
just recently like a week or two before. i checked it aswell
Hamer007 Jul 28, 2011 11:19 PM
I got a call from the mechanic today, it was a rocker that fell off :)
Didn't break anything, still had that rough idle, so there looking into that as well, might have them fix it all up while its in the shop.
Hamer007 Aug 25, 2011 09:18 PM
Rocker Arm fell off
ok i was driving and my rocker fell off (playing to hard)... anyways i took the valve cover off and one of the rockers in the middle was sitting off nothing bent just pushed off. soooo i was wondering how do i get that back on the cam guide. do i have to take off camshaft? or can i slip it on again? :017:
ty in advance :)
NismoPick Aug 25, 2011 10:03 PM
Merged with your previous thread... in which you stated the shop found the rocker problem... so... did they fix it and it fell off again? Or is this the same problem?
Also, time to break open that HAYNES manual or FSM. :D
Click: https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/aftermarket-cams-cam-removal-installation-pics-19939/
Hamer007 Aug 25, 2011 10:12 PM
Click: https://www.zdriver.com/forums/showthread.php?t=19939
Thanks.. they fixed it and i drove it again till i played to hard and it came off again, but i wanna fix it myself not a 150 dollar bill. i just need to slip the rocker on the guide. so whats the easy way to do this. i got a new guide btw.
Hamer007 Aug 25, 2011 10:15 PM
i can simply just push the valve down and slip it on?
NismoPick Aug 25, 2011 10:45 PM
Dude... did you look at the link I posted? Do you have a Haynes manual?
You can download the FSM from www.xenons130.com/reference and it has detailed steps on rocker R&R.
