ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   Power locks and windows (https://www.zdriver.com/forums/280zx-s130-forums-77/power-locks-windows-28303/)
280zdude Apr 10, 2009 10:10 AM
Just curious but does any one know WTH they put power windows but not power locks on an 82 zx.
On that same note, has anyone here moved their window switched fromt the door to the console. I keep hitting mine with my knee and it will sort scare the crap out of you when you are making high speed manuvers and the window start going down. Anyway, i was just wondering how much trouble it is to move them from the door to the console.
NismoPick Apr 10, 2009 10:13 AM
82-83 ZX's have power door locks... the driver's door locks & unlocks the passenger side.
Do you not have the plastic frame cover for the window switches? It wouldn't be hard to move them, just gotta rewire it...
280zdude Apr 10, 2009 10:15 AM
explain the power door locks. I am used to domestic autos that have the actual button. this has no button.
NismoPick Apr 10, 2009 10:21 AM
Lock / unlock the drivers side... the passenger side locks / unlocks. I don't think the passenger side will do the drivers side though.
280zdude Apr 10, 2009 10:22 AM
what about when you enter the car, if you unlock the drivers door with a key should it unlock the passenger door at the same time?
NismoPick Apr 10, 2009 10:24 AM
Yep. The drivers door lock system has an actuator that sends the same signal to the passenger side.
280zdude Apr 10, 2009 10:25 AM
what if it ain't working, where should i start looking?
NismoPick Apr 10, 2009 10:30 AM
In your Haynes manual. :D
Then on to fuses, relays, wiring, actuators....
280zdude Apr 10, 2009 10:32 AM
Cool. I can't wait to get that working. I hate making someone stand outside while I try to get settled in my fetal position for driving.
JhnRX7 Apr 10, 2009 09:03 PM
On mine, the passenger side locks with the driver side... however, it will not unlock with the driver side. I just assumed thats how it was supposed to be.
I need to figure this out and get it fixed!
280zdude Apr 17, 2009 05:51 AM
OK. I found a section in the manual I downloaded about the power locks, but it doesn't tell me where the flippin fuse is located. I looked all thru the owners manual, and on the front side of the fuse cover...nothing about power locks. I am going to try to fix this this weekend, but I sure hate starting off blind. Any help will be greatly appreciated.
Bleach Apr 17, 2009 07:53 AM
your passenger side actuator probably is broken. I had that happen. Open up the door panel from the inside and look.
From the factory, the pass door is the only door with a mechanism. My 280ZX has power locks both sides but the actuator in the driver's door is aftermarket and hooked up to an aftermarket alarm. (keyless entry!) :)
280zdude Apr 18, 2009 09:13 AM
Well bleach you were almost right. It was acually missing....ARGH!!!! On to the scrap yard......one day.
nismo619 Apr 18, 2009 01:23 PM
on my 1983 n/a/ the passengers side locked both sides as well as the drivers side. my 1982 has key problems im savin up enough money to buy new keys.
KingDatsun1 Apr 18, 2009 05:39 PM
I put keyless entry on my car and regret it,
sometimes it works, sometimes it doesn't.
much easier unlocking the car manually imo.
