P90A head what can i use it for
Old Aug 1, 2012 | 09:52 PM
koprutzxt's Avatar
ok so i had this head that a machine shop botched and to level it out it was shave by a bit (by another shop). im not sure about how i can use these mesurments to see what the haed is still good for.. anyways on the under side of the head next to each pair of valves it reads .034 i believe it was the amount shaven off ..???
its a fully rebuilt head so id like to make use of it or possibly sell it..
can any one help..
Old Aug 2, 2012 | 08:01 AM
.034 is etched in or stamped?
Have you tried asking the shop what it means?
Old Aug 2, 2012 | 11:59 AM
koprutzxt's Avatar
its looks like just marker .. ok so if its the amount shaved off what does that mean??? can it be used??
i know usually they shave off like a 100th, but clearly here it has moved to the 10th position.. which can be alot ..
im at work passing my time here so id like to discuss befor i call him tomorrow??
Old Aug 2, 2012 | 12:21 PM
1mm = 0.039369091in
I would assume .034 would be the amount shaved off, since the valves are 44 & 36mm and the combustion chamber should be around 53.6cc. I don't know why it would be written inside all 6 cylinders though...
You can machine up to ~.080 before needing shims.
And if you are sitting on your thumbs at work, why wait until tomorrow to call?
Old Aug 2, 2012 | 03:13 PM
koprutzxt's Avatar
Well here in the hospital we have wi fi and no bars. I thank u to not judge my actions.. So what do yall think, can I put the head on my na??
Old Aug 3, 2012 | 03:35 PM
koprutzxt's Avatar
bump
can i use the head still ?? i plan on rebuilding an n/a motor for use or sale can start this weekend if i get the ok ??
Old Aug 3, 2012 | 03:44 PM
cc the head then plug the numbers into the ozdat L series engine calculator. That way you'll know what compression you'll be running.
xcom90
Nov 14, 2012 08:17 PM
juan240z
Mar 13, 2012 10:58 AM
veyenyl
Jan 26, 2011 11:15 AM
Dashibhs2004
Apr 20, 2006 04:35 PM
datto
Oct 23, 2001 11:11 PM
