Oil pressure?
Old Dec 1, 2008 | 04:19 PM
KingDatsun1's Avatar
Oil pressure?
My pressure gauge is at zero...it was working a feel days ago... Theres still oil there and everything, no knocking either. Whats the deal?
Old Dec 1, 2008 | 04:21 PM
Did you check the wiring? Is the red light on? The needle doesn't even move when rev'ing? Sounds like the oil pressure sensor....
Old Dec 1, 2008 | 04:52 PM
yeah needle doesn't move at all... I hope its nothing serious lol
Old Dec 1, 2008 | 05:11 PM
Ratfink's Avatar
Hoov for Pres!
If you actually had no oil pressure, it would not take long at all to know for sure.
My guess is the gauge or the wires to it. I don't like digital gauges for that reason. Old school pressure gauges are nice.
Old Dec 1, 2008 | 07:47 PM
I'm not sure why you referred to digital gauges... are you thinking that the 83 digital dash had a digital oil gauge? Because it doesn't.
Old Dec 1, 2008 | 09:36 PM
No...it sure doesn't. lol I have an '83 with the digital dash package. I'll probably fix it up and keep it original and sell it. Anyway back to the thread at hand. lol
Yeah I would say check the plug on the oil sender. May just need to bend the tabs (or contacts) a little. I had to to that on mine. And it sometimes will get loose on me. And like NismoPick said earlier. Could also be your oil sending unit itself. Oh...go ahead and check your fuse too. There is a fuse that runs those 3 gauges. Good luck man.
Old Dec 1, 2008 | 10:01 PM
lww's Avatar
lww
Head Muckraker
It's probably a loose connection on the oil pressure sending unit or the sending unit has just gone bad.
Old Dec 1, 2008 | 10:14 PM
Ratfink's Avatar
Hoov for Pres!
I meant electric, not digital. Sorry.
Yeah, I knew it was in the gauges to the side, not the digital cluster.
I meant, an actual pressure gauge that itself uses the pressure to move the needle.
I have gauge sets that I can plug into anything, in a ton of different ranges up to 20,000 psi.. When I have a doubt, I plug it in.
Sorry, I reread the post, and I didn't make it clear at all.
Old Dec 4, 2008 | 04:28 PM
it was completely unhooked, I must have knocked it loose last week replacing the alternator hahah
thanks guys
Old Dec 4, 2008 | 08:42 PM
w00ps.....
Old Dec 6, 2008 | 10:53 AM
FubarI33t's Avatar
i had this issue when i was first trying to make my car run. replaced the sensor. worked great for a few months. had to replace again. the sensor is a Easy change if you have spares.
FubarI33t
Apr 27, 2010 08:45 PM
FubarI33t
Dec 12, 2009 10:03 AM
tonsoffun300zx
Sep 21, 2009 10:51 AM
y2daniel1981
Oct 25, 2006 10:24 AM
91zxtt
Mar 5, 2004 11:00 AM
