oil pan bolt
Old May 12, 2009 | 04:55 PM
hchase17's Avatar
oil pan bolt
I have a very small oil leak from around my oil pan bolt. Its not even enough to really make a difference but it bothers me either way. I think its also only when I'm on a hill becasue I changed my oil over a week ago and its not showing low at all on the dipstick. Any way I can stop it and still be able to get the plug out later on?
Old May 12, 2009 | 06:46 PM
septerra's Avatar
ZX2802
how do u guys get under your car?? I can get 2 sets of jacks from my mates. But is it safe to get under the car support from just those.?? Any ideas?
Old May 12, 2009 | 06:55 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
leaking from the drain plug?
If you are needing it fixed before your next oil change, you could have a friend hold a wet/dry vacuum hose to the filler (the suction should keep the oil in the motor) and undo the plug put a gasket on from an auto parts store... but keep a drain pan under the car just in case
Old May 20, 2009 | 09:26 PM
hchase17's Avatar
well it has a new gasket. i was thinkin the other day that it may be too stiff and needs to be driven on a little bit to conform to the bolt/hole.
RaTT92
Oct 28, 2010 06:26 AM
MR2Jake
May 28, 2010 11:05 AM
bluefairladyz
Oct 21, 2004 06:52 AM
