Now what else
Now what else
Ok. I tryed to mess with my car again today. Now the ecu won't power up. put another one in. it won't eater. fuel pump won't cut on cause ECU don't. I went over all connection's and grounds. nothin is missin or unpluged. What The Hell
check the fuselinks to make sure none of them blew. check the fuses. Check the ignition switch. check the relays. If you unplugged anything, make sure you plugged it back in. And make sure the battery is hooked up.
check power at the fusable links. Stick the voltmeter in there. The cover says which ones are for accesory and so forth. See you have power that comes on when the key turns to ON. If not.... uhh... then make sure the plug on the back of the ignition switch is still there.
i checked the power at the fuses. And I don't have fuse links
. I updated that about a year ago. Now it's a 98 Pontiac Grand Am fuse box there. three 60 Amp's and two 40 Amp's.
Ign switch is good. everythign else cuts on with key. just not ECU.
