New seats
Old Apr 7, 2010 | 11:32 AM
ZXT83's Avatar
New seats
I've seen that people put crx seats and miata seats in there z's. I just wanted to know if anyone has ever put integra da seats in there z. I bought a pair for a primo price and couldnt pass em up.
Old Apr 7, 2010 | 12:24 PM
ZXT83's Avatar
Didnt want to make another thread. Were do you guy get your block off plates? Do you just fab them of can you buy them? I want to clean up my intake manifold.
Also, for plugging the holes in the intake manifold do you just get bolts for a hardware store?
Old Apr 7, 2010 | 12:45 PM
If the Acky seats are the same bolt pattern... they should fit.
And which intake "holes" are you wanting to block / plug?
Old Apr 7, 2010 | 01:41 PM
Used a 1/8" aluminum plate traced it out - easy to cut and shape. Standard metric screws and high temp gasket sealant (not required but had it on hand). Easy peasy....
Old Apr 8, 2010 | 08:56 AM
ZXT83's Avatar
I wanted to block off the egr, aac, pov, and run a straight line from the air regulator to the j-pipe.
Old Apr 8, 2010 | 09:04 AM
ZXT83's Avatar
I want my intake mani to look like this
Old Apr 8, 2010 | 11:16 AM
That is a non-turbo intake manifold so no block-off plates are on the top of it like you would have on your turbo manifold.
Old Apr 8, 2010 | 12:30 PM
ZXT83's Avatar
Sorry wrong pic. More like this but what could i use to plug the whole were the pov is?
Old Apr 8, 2010 | 12:56 PM
^^^ That's Bleach's.
Clicky: https://www.zdriver.com/forums/showp...ostcount=10049
Use a plug from your local hardware store.
Old Apr 8, 2010 | 02:53 PM
I think I heard a trick for plugging that POV.
The intake manifold of a Z31 has a screw in plug in it that fits the 280ZX manifold in that spot. Just take one from a wrecking yard.
Yeah, this hose design is genious! If you can get the bypass valve out, the bolt blocking it is the L-series oil pan plug.
Old Apr 13, 2010 | 08:24 AM
ZXT83's Avatar
would it make a difference if i removed the pov after installing a bov? Or would it just be best to keep it?
Old Apr 13, 2010 | 08:45 AM
BOV's & POV's serve two different purposes. I'd type it here, but since I've typed it many times before, I give you the offer to search & find it.
Old Apr 13, 2010 | 01:44 PM
The bypass valve may be what you were wanting to ask about. If you leave it in, there won't be enough vac/pressure to release the BOV anyway. I'm pretty sure the bypass will override it.
POV releaves overboost pressure from the intake manifold.
Old May 5, 2010 | 06:22 PM
ZXT83's Avatar
http://i110.photobucket.com/albums/n...r/100_0624.jpg
http://i110.photobucket.com/albums/n...r/100_0623.jpg
http://i110.photobucket.com/albums/n...r/100_0611.jpg
Thanks Bleach
nismo619
17
Oct 30, 2006 07:17 PM
thxone
May 18, 2006 03:37 PM
petrol
Jan 13, 2006 08:20 PM
Lion00
Sep 27, 2003 03:18 PM
Lion00
Aug 19, 2003 10:34 AM
