In need of some help
Old Oct 20, 2009 | 09:32 PM
Cali79zx's Avatar
This is my first time doing this so be gentle.
I just got my hands on a 79 280zx, but I have been having a lot of white smoke once the engine gets to normal temp. I am aware that chances are I either have a blown head gasket, or a crack somewhere in the head.
My questions are these...
What would be the best to do if I have a crack in the head? Replace only the head? Find another L28E? Or go with some kind of engine swap?
If its just a blown head gasket I am going to simply replace the gaskets and run with it.
Any advice would be great. Thanks
Old Oct 20, 2009 | 09:59 PM
skib's Avatar
This facepalm's for you!
If the head is warped you can have it decked (shave it down so its strait) or just pick up a new head.
Theres plenty of em around for parts, Iv got at least 4-5 sitting in my shed for various nissan/Z motors
Old Oct 22, 2009 | 06:47 PM
Cali79zx's Avatar
Thanks for the info; however, I would like to know what I should do if the head is cracked, not warped.
Old Oct 22, 2009 | 07:18 PM
Take it to a trusted machine shop and have them check it out. Most will check it for free to $20.
If it's cracked, and depending where, you could have it welded & re-surfaced / ground. A cracked aluminum L-Series head is pretty rare though.
Please explain when, where, and how this happened, so we can get a better idea if it really is a head issue.
Have you checked all the spark plugs? One or more "steam cleaned" tips will be a dead give away. Also coolant in the oil (milky brown oil) or oil in the coolant are classic signs. Bubbles in the coolant when you remove the radiator cap, disappearing coolant, overheating, etc....
Please tell more about what is going on.
Old Oct 22, 2009 | 09:20 PM
Cali79zx's Avatar
I have worked on cars for a few years and I checked for all the obvious signs. Including those stated above. I did not notice anything out of the ordinary. The only symptom I have been getting is a constant white smoke once the engine heats up. I am in the process of taking the engine apart to determine if it's a head gasket issue. Between work and school, the amount of time I can dedicate to this project has been diminishing.
I will keep you updated on the progress.
Old Oct 22, 2009 | 09:25 PM
< cough >
Sounds like you know what you are doing then? I'm just checking in case you don't need to do all that work... ya know.
Old Oct 22, 2009 | 09:36 PM
BlueKitsune's Avatar
Intrawebz Wizard
Try retorquing the headbolts first. And you do know that if theres some water in your catalytic converter wit will smoke once hot as well. if its your head gasket it should smoke all the time, hot or cold...
Old Oct 22, 2009 | 09:38 PM
Cali79zx's Avatar
hahaha yeah I know. I have done a few gasket replacements I just haven't had a cracked head and I honestly didn't know what to expect. Thanks for the help
Old Oct 22, 2009 | 09:45 PM
skib's Avatar
a cracked L head is very rare, its going to warp long before it cracks
Old Oct 30, 2009 | 05:48 PM
Cali79zx's Avatar
I have another question. For those of you that have taken apart a L28E engine, what type and size socket do I need to remove the head bolts? It looks like an oversized allen wrench, and I don't want to be buying tools that are the wrong size if I don't have to. Thanks
Old Oct 30, 2009 | 05:59 PM
Hum... I have one in my tool box in the garage... I can't remember the size right off the top of my head. A quick google search or looking through the Haynes manual or FSM should tell you.
Old Oct 30, 2009 | 06:02 PM
Cali79zx's Avatar
Haynes Manual doesn't have it. I will check out the google search, but FMS? I honestly have no idea what that is
Old Oct 30, 2009 | 06:03 PM
FSM = Factory Service Manual ... www.xenons130.com/reference
Old Oct 30, 2009 | 07:14 PM
Intrawebz Wizard
10mm Hex
