need serious help !!
Old Aug 25, 2011 | 11:46 PM
ozone82's Avatar
Angry need serious help !!
Alright you guys so this is whats happening. Car runs fine for about first 10 minutes when turned on. After those ten minutes, i rev the engine and it instantly starts to backfire and choke. RPM wont rise about 1000. Cant drive it at all. this is a list of parts i have changed.
AFM,fuel pressure regulator, chts, tps, fuel pump,ignition pick up coil,CAT,oxygen sensor, igniton module,ignition pick up coil, ECU,EGR,
Can it be the distributor?? PLease help
Old Aug 26, 2011 | 12:00 AM
zenzee's Avatar
problem of car back firing and no power
Check Ignition timing and timing chain mechanism. Also condition of cylinder head valves etc. o/k.
Old Aug 26, 2011 | 12:15 AM
ozone82's Avatar
cylinder head valves are all good. havnet checked the timing chain, and how would you check the ignition timing??
Old Aug 26, 2011 | 12:40 AM
DuG's Avatar
DuG
ten minutes is time for the motor to heat, do you know / have you check any element working only after the motor is at the good temperature ?
Old Aug 26, 2011 | 09:54 AM
ozone82's Avatar
Element? What do you mean? ?
