My turbo plenum....
Old 04-16-2011, 12:00 PM
My turbo plenum....
I finally got around to opening up the plenum on the turbo plenum I'm modifying. I ported the runners and setup for the 240SX TB as well as removing the webbing. Now I can get at the backside of the runner. The radius entry on the stock is pretty decent but we'll get her cleaned up ported and polished up now.
Attached Thumbnails My turbo plenum....-turbo-plenum-cut-away-1.jpg   My turbo plenum....-turbo-plenum-cut-away-2.jpg
FricFrac is offline
Old 04-16-2011, 07:04 PM
Very awesome!!!
NismoPick is offline
Old 04-16-2011, 09:33 PM
zordietrying's Avatar
What did you use to de-web and cut it open?
zordietrying is offline
Old 04-16-2011, 10:13 PM
My wife's finger nail file.... pretty impresive eh?
FricFrac is offline
Old 04-17-2011, 01:35 PM
oh man... a finger nail file woulda been so much easier than my drill, chop saw, and grinder when I did my S30T swap!!!
Old 04-17-2011, 07:05 PM
Lol - yea I drilled along the edge of the runners then just punched out the webbing. I had the manifold sitting there for about three months trying to figure out how to open it up. Turns out you can use the same air die grinder I used for porting and polishing but just used a zip disk and cutting wax (that's the tube of white wax to the right is). Just marked where I wanted to cut along the bottom and side took my time and kept waxing the disk.
FricFrac is offline
Old 04-18-2011, 05:41 PM
i used an aluminum wheel on my straight air grinder. made quick work of it. then a aluminum burr to clean it up. im just gonna make my own manifold here eventually. all im gonna keep is the flange and where the injectors go. rossmachining sells the materials to make quick and easy mainifolds for resonable prices.
SHADY280 is offline
Old 05-04-2011, 10:15 AM
EGR runner delete.....
Taking out in sections to make sure I don't cut into any runners...
Now I just need to clean it up a bit....
Attached Thumbnails My turbo plenum....-plenum-egr-delete-1.jpg   My turbo plenum....-plenum-egr-delete-2.jpg
FricFrac is offline
Old 05-09-2011, 08:31 PM
Just got the EGR runner holes welded up... next step is to grind 'em down...
FricFrac is offline
Old 05-12-2011, 12:18 PM
EGR holes welded and re-ground....
FricFrac is offline
Old 05-12-2011, 12:22 PM
Since you removed the entire bottom EGR run, why not finish the de-webbing up to the plenum (aka... look like the N42)?
PS... very good job on the runner grinding / clean up!
Old 05-12-2011, 02:39 PM
That is very clean! good job.
Don't forget about this weekend
Bleach is offline
Old 05-12-2011, 03:13 PM
S2z
S2z's Avatar
Being a cylinder head porter myself, I feel your pain!!!!
Nice Work!
S2z is offline
Old 05-12-2011, 04:28 PM
The webbing between the outer runners is very close to each runner and I didn't see any benefits of removing it vs the risk of making the wall thinner on the runners. I also wanted to keep the flange on the face to keep it stronger - more work but I think it will help keep it true....
FricFrac is offline
Old 05-13-2011, 12:06 PM
.... final results for the runners from both sides....
Attached Thumbnails My turbo plenum....-plenum-runner-1.jpg   My turbo plenum....-plenum-runner-2.jpg   My turbo plenum....-plenum-runner-3.jpg   My turbo plenum....-plenum-runner-4.jpg
FricFrac is offline
Old 05-13-2011, 02:11 PM
+12hp!
SCORE!
Bleach is offline
Old 05-13-2011, 04:25 PM
Originally Posted by Bleach
+12hp!
SCORE!
That's it? A Pioneer sticker is good for +10 HP ;P
FricFrac is offline
Old 05-31-2011, 11:32 AM
...ready to weld up...
FricFrac is offline
Old 06-07-2011, 12:35 PM
Powder coated with 240SX TB and spacer
FricFrac is offline
Old 06-07-2011, 01:00 PM
West Coast!
tonsoffun300zx's Avatar
you should have grinded down the weld it would have looked much cleaner but who am i to say what.
tonsoffun300zx is offline
Old 06-07-2011, 04:24 PM
First of all the weld is on the bottom so you'll never see it when it's mounted on the car. Secondly the skin of the weld is the strongest part. It cools the quickest and gives the weld the majority of it's strength
FricFrac is offline
Old 06-07-2011, 05:31 PM
West Coast!
shows you how much i know about l28's
Old 06-07-2011, 05:36 PM
Lol - grinding the weld down has nothing to do with L28's....
FricFrac is offline
Old 06-08-2011, 05:30 AM
Primer Grey FTW!
evandubya's Avatar
Beautiful weld!!!!!!!!!! You are correct, leaving it there for strength.
evandubya is offline
Old 06-08-2011, 06:17 AM
A friend of mine did the weld. He's a welder with a LOT of welding experience. He doesn't do any fabrication other than welding and he's been doing it for 25+ years so he really is an expert. Interesting to note was that he said the aluminum in the manifold was excellent and very easy to work with with no porosity (sp?) in the metal. Another quality Nissan part
FricFrac is offline
Quick Reply: My turbo plenum....
