My blower unit is malfunctioning and I got the shivers! HALP!
Old Oct 2, 2010 | 06:30 PM
280zx2by2's Avatar
Haterade by da gallon!
When I turn on my AC or heater the blower sometime will not work or it will work but at some point down the road it just shuts off. Its been a problem ever since I have gotten the car, just one of those things that slowly gets worse and worse and now it will almost never turn on. I know the heater (and AC for that matter) work because I can feel heat coming from the vents slightly.
Ground? Relay? Switch? Idk.....
Plez helppp.
Old Oct 2, 2010 | 07:44 PM
Maybe your climate control switch is wearing out. I know mine doesn't work at all. But when I hooked my blower motor directly to my battery. It worked perfectly. So I need to get a toggle switch to run the a/c and heat. Hopefully you get it figured out. Good luck.
Old Oct 2, 2010 | 09:13 PM
duckyz's Avatar
There's a fuse up under the dash right next to the blower...hell it may be ON the blower for all I remember. Make sure the connections are clean and the fuse is good.
Old Oct 2, 2010 | 09:24 PM
^ I believe I changed it out, and still it didn't work. I am pretty sure my climate control switch is shot. Not sure if his is though.
Old Oct 3, 2010 | 06:20 AM
280zx2by2's Avatar
When you say climate control switch are you revering to the blower fan speed switch? Because 81's didn't come with a climate control cabin temp sensor/switch.
Old Oct 3, 2010 | 10:03 AM
No, just the manual control switch. That has the **** to adjust the speed of the fan. And the levers for hot and cold, and also vent.
Old Oct 3, 2010 | 05:09 PM
280zx2by2's Avatar
Just realized something, the stock switch is a multiple resistance switch, how is wiring in a toggle switch going to affect that?
Old Oct 3, 2010 | 05:55 PM
BlueKitsune's Avatar
Intrawebz Wizard
It will either be full blast or entirely off. Not variable like the pot.
Old Oct 4, 2010 | 03:44 AM
I would be wiring the switch directly to the blower fan itself. Thus by passing the non working climate control switch. And it would be on full blast. Until I get around to finding another climate control switch. It would be better than nothing at all.
Old Oct 4, 2010 | 03:33 PM
280zx2by2's Avatar
Thanks guys, Ill see about getting a temporary solution going.
Old Oct 4, 2010 | 04:39 PM
J-cubZ's Avatar
At least you have hot and cold... I have whatever is outside.
Old Oct 6, 2010 | 04:58 PM
bsmuwk's Avatar
The blower and all that nonsense is dead on my Z, so I'm with you there.
I gotta figure out how to at least get the fan going and then how to get the heater going.
Old Oct 6, 2010 | 05:09 PM
Intrawebz Wizard
Me as well, my AC works when it feels like and I have no heater core so... winter is gonna suck.
Old Oct 7, 2010 | 03:28 PM
J-cubZ's Avatar
Yikes!! Yeah my blower works great through any vent i choose... Just can't controll the temp. I don't even know why, stupid auto climate!!!
WanganDevilZ
Aug 21, 2012 04:14 PM
83Zturbo
May 16, 2009 12:54 PM
OlderThanMe
13
Sep 16, 2005 02:44 PM
joelacer
Apr 25, 2005 07:29 PM
casdebin
Sep 26, 2002 02:13 PM
