ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   My '82 is running better! (https://www.zdriver.com/forums/280zx-s130-forums-77/my-82-running-better-21854/)
WildmaN Feb 18, 2007 02:33 AM
I decided to swap out AFM's once again. I got another one on e-bay for cheap. And put it on, yesterday. Wow what a difference, I actually have gained some power back. I had to adjust the idle screw, because the ECU was trying to adjust to the new one. And as soon as it did, I had to turn the TPS counterclockwise. So here soon, maybe later today. I will change the oil to the high mileage Castrol, and see if I can get a little more power back to #3. It is wishful thinking, but it seems my oil burning has slowed down, since I have started adding the high mileage oil, when he needed to be kept to the full mark. So I am going to change it all to that type of oil. And see what happens, it is worth a shot.:unibrow:
I am also going to recheck my timing again, and see if it needs to be resest. Now that my Z is running correctly, I might need to change it again. It doesn't hurt to look and see. Because I think he has been running wrong ever since, I put that other AFM in him. I think it is the wrong type for my engine. Maybe it came off another Z, like an older one.
flightforlife07 Feb 18, 2007 02:59 AM
have you ever heard of Lucas? we started using Lucas oil stabilizer in our trucks that have a high consumption rate and it seems to have slowed it down significantly and it supposed to add a lot more additives to your motor oil. I don't know if your motor is consuming the oil or not but its worth a try to put a stabilizer in it i think. Its about ten bucks a bottle or so which is a low cost to preserve your motor any how see what everyone else thinks.....
FubarI33t Feb 18, 2007 05:44 AM
i use 20/50 in my car. That slows down the burning.
WildmaN Feb 18, 2007 02:14 PM
Yeah I have always used 20-50 in all my cars. Because of the hot climate here, it works great. I might check on that Lucas oil, thanks for the tip.
skittle Feb 18, 2007 02:45 PM
good luck to ya wild, good to hear you have made some progress
WildmaN Feb 18, 2007 03:07 PM
Thanks man, and more than you know. Check out my new thread in off-topic. It will be worth a look.:unibrow:
snwbrderphat540 Feb 18, 2007 03:29 PM
car runnin good eh... gonna go pic up your russian gal in the Z? do alittle first impression impressin. oh and congrats and good job.. im proud to say once i get my IC in ECU and oil T anf feed line i may have a quick surprise for all on that satus of my car... but i make no promises ;)
CraigS Feb 18, 2007 04:30 PM
Yes, woo her somehow. Your car is still in primer so paint it up for cheep like someone on HybridZ did HERE. Its easy, cheep, multiple colors give you a broad choice, and if you decide to paint it for real you can take it off without it being a health issue unlike rustolium.
WildmaN Feb 18, 2007 05:02 PM
That is a good idea. But if she only likes me for my car. I am not interested in her. Not saying, I don't mind that they like my car. But I am not wasting money on a paintjob, that will be stripped, for bodywork and such. When I am ready to do the turbo swap. I have gotten compliments, on my Z being primered. The primer hides his flaws more. It is only temporary, but will change after the turbo swap.:unibrow:
SHADY280 Feb 18, 2007 06:35 PM
my bro's g/f has a drag car, that lucas sponsers. it pretty good stuff that actually works. i thought it was snake oil, but it really works.
WildmaN Feb 25, 2007 08:57 PM
Well a little update on my Z. I figured I would put it here. I changed out the oil, and put Castrol 20-50 high mileage, with a Purolator filter. Wow my oil pressure has never been that high. And I also cleaned my o2 with my wire wheel, on my drill. And boy does he have some more get up and go! I am going to be surprised when I have a Z, with a rebuilt, or reman motor. My Z is pretty quick with bad compression, in one cylinder. I couldn't imagine a n/a fresh, or a turbo. That is going to be scary.
