ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   Msd (https://www.zdriver.com/forums/280zx-s130-forums-77/msd-30025/)
FubarI33t Jan 19, 2010 07:37 AM
Msd
Yes i have been lookin. I want a quick response if possible, as soon as ya'll say this set up will work on a 83 N/A with stock dizzy, ima hit order button. If i am missing anything, awesome time to tone in. If you also think a turbo dizzy will work better. that thought is also much appreciated.
Ignition
http://www.summitracing.com/parts/CRN-6000-6300/
Coil
http://www.summitracing.com/parts/CRN-730-0891/
Plug Wires
http://www.summitracing.com/parts/TAY-50047/
If ya'll think i can do dizzyless for same as above. let me know. options are open till i check out.
NismoPick Jan 19, 2010 08:11 AM
That Crane ignition should work, but you will probably have to use a tach converter if you are keeping the stock tach.
I'm using the Mallory Hyfire VI-AL (http://www.summitracing.com/parts/MAA-6853M/), MSD Blaster II coil, and MSD tach converter (http://www.summitracing.com/parts/MSD-8910/).
The Mallory (same as the MSD VI-AL) puts out more volts than the Crane, but looks like it's more expensive. I actually bought my VI-AL on ebay for $80 new. :D
FubarI33t Jan 19, 2010 10:11 AM
from what i am reading on hybridz a tach adapter is not needed. Since i don't plan on going turbo, this system should work great for any N/A. the Mallory unit does not show what it's max compression. Although the Crane is rated for 8,000 (10K for 4 cyl) i dought i will ever get that high. also the crane is rated for a good 9:5 comp. that will be about the max i will ever get due to i must be able to run 87oct with out ping.
bojo68 Jan 19, 2010 02:11 PM
I know many will probably use this for an excuse to bitch, but my experience with MSD is it stands for "MIGHT SUDDENLY DIE". Textbook definition of a P.O.S far as I'm concerned, I'd run a model T coil first. Look at the Winston Cup cars, they run TWO MSD ign units, despite the weight and 400$ price, change them BOTH every race, and they still aren't dependable.
It has been proven to me thaty MSD KNOWINGLY sells NEW stuff that DOES NOT WORK, and never did. Further, they kept up the charade for over a year, just so ya know their integrity level. If ya don't believe me, do a search for turbo BTM units.
John Mihovetz(worlds fastest ford modular owner, 6.23 1/4) uses Evinrude outboard coils, at 50 plus intake pressure and 10k rpm on a v8, and works well enough. I don't see the need for MSD, there's better, cheaper stuff out there.
NismoPick Jan 19, 2010 02:57 PM
Like Mallory. :D As for your argument of changing the boxes every race... they do that with just about every other part of the car between races too, because just about every part of the car is maxed out at every race. Nascar isn't like grandma's Sunday drive to church.
bojo68 Jan 19, 2010 05:33 PM
Heh, it would be hard NOT to be better than MSD.... They make good garbage can fillers, not much good as boat anchor either....
thetremendousti Jan 19, 2010 06:10 PM
bojo!! you're back!!
SHADY280 Jan 20, 2010 04:48 AM
you need the tach adapter for it to work on a s130. i tried without it, no dice. it wont run the fuel injection either
FubarI33t Jan 20, 2010 05:13 AM
Well so far i have the crane cam ign selected. But i might still try to run on my Fiero ECU and system mod idea. it's a HEI system, 2.8LV6. A MAP sensor and no AFM sounds good to me. i brought it up here ages ago, and back then it was feasible between many ppl here. might be a good time to pursue it.
bojo68 Jan 20, 2010 01:47 PM
Don't really know that system, but if your considering trying to install a speed density system, ya might wanna consider how BIG a box of Preparation H your going to need to get it tuned right. I wouldn't dream of trying to tune a speed density sys to a different engine. There are self learning maf systems available for a lot less than I'd think anybody that makes minimum wages time is worth.
Not telling ya what to do, just tipping ya off to what ya might be stepping into...:)
FubarI33t Jan 21, 2010 04:02 AM
I know the system still uses a dizzy. so it's not exactly the same as there systems they use like on Lumina's and what not. I almost tryed the system except some one traded me a great cond 300zx for the feiro,
FubarI33t Jan 21, 2010 05:55 AM
I just looked into MS again. i guess the prices have gone down. i can replace everything with a MSII with PCB2 for the same price. controls the fuel and spark. heck i'm sold
PurePontiacKid Jan 21, 2010 11:11 AM
That must totally be why the 20+ year old unit in my Firebird still works wonderfully... lol (I guess the old adage goes, "they don't make stuff like they used to anymore)
NismoPick Jan 21, 2010 11:36 AM
I still don't agree w/ Bojo's statement of how crappy MSD is....
If MSD wasn't dependable, don't you think Nascar / Winston Cup cars would STOP using them?
"These are crap! But we'll use them on our million dollar cars anyway... just so we can lose... cuz losing is cool..."
:D
bojo68 Jan 21, 2010 04:14 PM
NOW yer talkin...:)
bojo68 Jan 21, 2010 04:21 PM
:D
Whatever. Their own instructions and web page at one time showed the wiring diagram for running 2 of them with a switch determining which one.
How many manufacturers stuff is so bad they show how how to use a backup in the instructions? If your curious, go to turboforums and look up the record they have there. I don't care, if you want tunnel vision, fine by me.
Bye the way, NASCAR rules require a distributor, not exactly a matter of whatever ya wanna run on million dollar car. Furthermore, there's a thing called sponsorship....which generally puts good cheap parts out in favor expensive crap...
PurePontiacKid Jan 21, 2010 04:58 PM
you're the one with tunnel vision, I've got proof, on two cars actually (my dad's got another old ass MSD [7AL-2] unit in his racecar) that they work just fine...
FricFrac Jan 28, 2010 03:24 PM
I bought the MSD because its one of the most reliable systems out there - tried and true. Of course there are going to be some failures in every system but after talking to quite a few people including a friend of mine who is a full time mechanic and works on a Sprint car pit crew said he rarely hears of MSD`s failing. There is a reason they are so popular with lot of other options out there. I went to a local car gathering and there were well over 100 hot rods there - EVERY single one that had a modified ignition system was MSD - seriously I was looking because I was trying to figure out what system to run in my 240Z. All of them made it to the car show....
If you`ve had one fail on you or you`ve had poor customer service you tend to get a bad taste in your mouth. People who have had problems with equipment tend to out vocalize those who haven`t.
When I switched to the MSD 6AL and MSD SS coil on my 240Z the engine was much much smoother and noticably peppier. Personally I`ve been very happy with my MSD. I saw another system that looked very interesting but I`ve forgotten the name of it. Very small about the size of a cigarette package...
...oh and you don`t get sponsorships from running equipment that doesn`t get you past the finish line....
FricFrac Jan 28, 2010 03:33 PM
I was told I needed get a tach adapter for the 240Z as it is a current triggered tach. Spent hours and hours reading on it. Turns out the manual for the 6AL had the fix right in it - a simple power resistor did the trick and the tach works. I am having a bit of an issue over 5K RPM but I think I just need to adjust the resistance for the higher RPM range to get the tach to trigger - haven`t played with that yet as the 240Z is in storage till the spring...
VenomousZX Mar 2, 2010 07:17 AM
I just had the stock ignition module on my ZX die, the Mechanic kept ruling out the failure of this component and I decided to go MSD 6AL & a pn#8910 tach adaptor, however you must keep your stock ignition module to send the input to the MSD, we ended up using a 1981 Toyota corolla ignition module with the MSD this is just to get me back home to Yakima so I can try & find a decent and working 280ZX ignition module...
bojo68 Mar 4, 2010 05:19 PM
I know all you experts think I'm nutz, but I intend to prove that a stock ign can run 8 second 1/4 times, something I doubt may here have even dreamed of.
snwbrderphat540 Mar 4, 2010 09:58 PM
damn now its 8 seconds?!?!?!?!?! wasn't it 9.5 at 150mph 2 days ago? setting the bar higher!!!
duckyz Mar 5, 2010 02:46 AM
...and this is going to be an N/A with less than $2,500 worth of mods? I gotta see this.
snwbrderphat540 Mar 6, 2010 10:56 PM
no its gonna have a HUUUUUGE blower on it and a 4.6 ford motor cause they are the best motors ever designed, jesus couldn't make a better motor himself man!!!!
hoov100 Mar 7, 2010 12:24 AM
I wanna see this stock ignition grow legs and run down the drag strip period! Are we talking about cars here bojo? on earth right? in this reality?
