a lil question about fuel
Old Jan 9, 2007 | 11:56 PM
antiman's Avatar
i have a 83 280zxt and the past month or so it has been fouling out plugs due to to much gas, anyone know a sensible place to start troubleshooting to save me a lil time?
Old Jan 10, 2007 | 12:38 AM
thxone's Avatar
Back your foot off the gas pedal....sorry, I couldn't resist....check the O2 sensor.
Carl's Z's Avatar
Check your AFM (See the sticky above on cleaning the AFM). What do your plugs look like?? Pics would help there! Get a Haynes manual and check out some of the OHM checks you can do on some of the intake components, including the Air Flow Meter (AFM), TPS (Throttle Position Sensor), and other heat related sensors around the engine compartment. Also, make sure your vacuum lines are intact!!!
If all that checks out. come back for more info, as we are here to please!
Carl's Z
P.S. Go cheapest route first, then go from there!!!
Old Jan 10, 2007 | 04:56 AM
turbot5's Avatar
install after the fuel filter a permanent fuel pressure gauge, a must for do it yourself people, or have the pressure checked, if FPR is acting up pressure will fluctuate, in your case will rise (from normal around 30 to 60's)...
Old Jan 10, 2007 | 05:02 AM
naviathan's Avatar
My buddy just purchased a 280ZX 2+2 that was doing this horribly. it would run for about 30 minutes before fouling the plugs. I tried swapping out the head temp sensor and cleaning all the contact and resetting the timing and etc...
Finally I pulled the cap and it was toast. Weak spark makes for fouled plugs.
Old Jan 10, 2007 | 06:45 PM
antiman's Avatar
here are some pics.. plugs are three weeks old
Old Jan 10, 2007 | 07:46 PM
thxone's Avatar
Dude! Not trying to be mean...but those pics suck...99% of all digital cameras have a macro setting for just such shots. It should look like a flower on the camera...retake the pics only this time use the macro and a darker background and let the camera focus....I want to see these plugs.
No Macro
Attachment 5694
With Macro
Attachment 5695
Old Jan 10, 2007 | 07:48 PM
skittle's Avatar
Taste My Rainbow
i thought the turbos have a maf not an afm???
Old Jan 11, 2007 | 04:19 AM
wgc_3's Avatar
On the 300zx your correct but 280 zxt are afm.
Old Jan 11, 2007 | 07:04 AM
skittle's Avatar
Taste My Rainbow
ahhhh okies
Old Jan 12, 2007 | 06:48 PM
antiman's Avatar
sorry bout the pics here are some better ones that have been wiped a little
http://i31.photobucket.com/albums/c3...8/HPIM0421.jpg
http://i31.photobucket.com/albums/c3...8/HPIM0420.jpg
http://i31.photobucket.com/albums/c3...8/HPIM0417.jpg
Old Jan 12, 2007 | 06:57 PM
thxone's Avatar
Those plugs look ok to me.
Old Jan 12, 2007 | 07:00 PM
get some NGK's
Old Jan 12, 2007 | 07:18 PM
skittle's Avatar
Taste My Rainbow
Yeah Those Plugs Are Fine.... Wait Till I Post Pics Of Mine.
Old Jan 12, 2007 | 09:44 PM
look at the pix of zachs plugs, those are fouled, the ones you have look o.k. whats your gap set at, too large can cause odd problems
Old Jan 12, 2007 | 09:47 PM
skittle's Avatar
Taste My Rainbow
Yeah Same With Too Small... If You Don't Have One Get A Haynes Manual They Are Invaluable
cpark_12
Aug 2, 2012 08:26 AM
Niku-Sama
Other Cars
Jun 24, 2011 10:25 PM
Cali79zx
Mar 19, 2010 08:14 AM
BigBirdsZ
Nov 11, 2006 09:44 PM
WildmaN
Jan 27, 2006 08:20 PM
