Installing amp
Old Mar 11, 2007 | 10:23 PM
Jadon's Avatar
Installing amp
Ok, so i just bought my 82 280zx and i'm installing an after market radio. after about 7 hours, i got all new speakers in and head unit. now i would like to install my sub and amp. but i cant find where in the firewall i could put the hot wire and i dont really want to drill but i will if i have too. thanks
Old Mar 11, 2007 | 10:43 PM
SpeciallySpiked's Avatar
I'm a Registered User!
I put mine through my fender, tomorrow i'll take some pictures for you when it's light outside if you'd like.
Mine goes into a hole right next to the fuses on the passenger side underneath the plastic trim. It then pops out up where the other wires for the door's windows/mirror come out and it then goes into the fender where there happens to be another hole leading to the engine bay...
Took a bit of time to do it but no one has ever noticed it.
Old Mar 11, 2007 | 11:03 PM
you can run it through the fender, or just push it through any of the gromets in teh firewall, efi or engine compartment harness gromet.
Old Mar 12, 2007 | 12:29 AM
chinesekid's Avatar
i put mines in the firewall where all the ele. harness comes in/out from..
Old Mar 12, 2007 | 05:38 AM
FubarI33t's Avatar
Mine runs though there too. I also have a vacuume line running though the throttle hole too.
Old Mar 12, 2007 | 05:40 AM
mrgoochio's Avatar
Just curious, does the 280ZX or any of the S30's have any existing holes where a 0gauge wire would fit through? In my last car, I had to drill because my 0gauge wouldn't fit. I was bumpin
Daniel
Old Mar 12, 2007 | 05:45 AM
FubarI33t's Avatar
you might be able to squeeze it with the ECU harness. other then that. The fender should be a spot for it. I got my Dizzy vaccume line running though my driver side fender.
Old Mar 12, 2007 | 05:48 AM
thxone's Avatar
Here is where mine is running through the firewall, it is a 4 gauge wire so I think you should have no problem with anything of this size and smaller....notice the auto tranny dipstick for location of this hole on an 82 280zx:
Old Mar 12, 2007 | 05:53 AM
FubarI33t's Avatar
That's one thing i don't miss. And that's that auto dip stick. I don't run wires like that. cause the sharp edge of the metal will eat though the insulator and short you out.
Old Mar 12, 2007 | 06:00 AM
thxone's Avatar
It is true, in "theory" the sharp metal edge "could" cut the wire but I am lazy and after fighting to cut through it with my "Wire Cutters" I think it will be just fine as it is stationary anyway and has an overly thick jacket on the wire...Stinger.
Old Mar 12, 2007 | 06:08 AM
FubarI33t's Avatar
the only reason i said something is because i sliced though my ECU harness. And i sliced though a Amp wire in my ranger.
Old Mar 12, 2007 | 09:29 AM
thxone's Avatar
I completely understand...I have seen it more than a few times myself....I am just lazy.
Old Mar 12, 2007 | 12:41 PM
Jadon's Avatar
thank you...
ooms9883
Jan 22, 2014 10:20 PM
ZXDriver
Aug 27, 2011 02:16 PM
casperzxt
Nov 19, 2009 11:02 PM
ggraphx
29
May 11, 2006 08:03 PM
cookiecutter
Nov 28, 2002 06:25 PM
