I turned the Key........
Old Nov 14, 2006 | 03:58 PM
FubarI33t's Avatar
Today i made the block off plates, and finished up the fuel system. I said what the hell. So I got in, turned the key to kick on the fuel pump. She built up pressure liek she was supposed to. Turned it one more notch to kick the starter............ Nothing! I was of course cussing up a storm, I got out grabed a screw driver, and went after the starter, unpluged the remote line, and tryed to start her by jumping it. Start=Good. Added a prime of fuel, and saw a purdy flame come out the intake.(i left a port open so i can add fuel) Tryed again. more backfireing. I set TDC and Dizzy before i put engine back in. So now. i got Starter probem, Backfireing, and injector fireing. First, Starter. What could that be?
Old Nov 14, 2006 | 06:01 PM
jfairladyz's Avatar
congrats Fubar, you are the 3,000,000 Z owner to report these types of symptoms after tearing apart some part of your engine
On the starter: Make sure the yellow wire to the solenoid is hooked up. Make sure the + battery cable is running to the starter. Make sure the starter is firmly bolted to the engine and that you have either a - battery cable running to the starter body or that your engine has a grounding strap running to the chassis.
On the backfiring: make sure your cam timing is correct. Make sure you have the dizzy driveshaft installed correctly at TDC. A backfire out the intake usually indicates most likely either **** poor ignition timing or **** poor valve timing. Some other common causes are crossfiring and intake valves not closing completely.
Old Nov 14, 2006 | 07:31 PM
FubarI33t's Avatar
Starter is hooked up right. and it's probly got to be the dizzy timing.
Old Nov 14, 2006 | 10:05 PM
i made this for a reason..
you never know, its simple to check, might as well check it..
Old Nov 15, 2006 | 06:41 AM
BigBirdsZ's Avatar
thats^a^quality^diagram^u^got^there^lol j/k
Old Nov 15, 2006 | 07:46 AM
straight out of the Nissan Factory Service Manual!
Old Nov 15, 2006 | 09:05 AM
FubarI33t's Avatar
Why do I feel like I have seen THAT pic before?
Old Nov 15, 2006 | 09:33 AM
because i corrected someone else's pic and im tired of people asking for the firing order, so i just put it up on the web..
Old Nov 15, 2006 | 03:25 PM
FubarI33t's Avatar
I knowthe fireing order. and my plugs are in the right place.
Old Nov 15, 2006 | 03:26 PM
just making sure..
larsol02
Jul 9, 2014 04:06 PM
wrenchwench
Dec 2, 2011 01:36 PM
The_MuffinMan25
Sep 21, 2009 03:30 PM
gostlrs
Jan 3, 2009 05:21 PM
