I screwed myself over!
So, I moved from North Carolina back to California.
And now, the 280 is illegal. I can't pass smog. Why? The stupid pipes are not original. Anyone willing to part with a stock j-pipe and Turbo airbox to help me out? Or at least give me some suggestions. Or I guess buy my car? I am incredibly stressed over this. |
Go to a smog ref and get them to sign off on it.
Pipes? Pipes? Which "pipes"?
I assume you mean intake? If you need a j-pipe, I guess that means you have an intercooler, and they are failing you for an intercooler? I hate guessing games... :D |
Originally Posted by hoov100
(Post 310103)
(Post 310104)
I assume you mean intake? If you need a j-pipe, I guess that means you have an intercooler, and they are failing you for an intercooler? I hate guessing games... :D Pipes! Yes I mean intake pipes. J-pipe: turbo outlet to throttle body Air box Pipe from air box to AFM and Pipe from AFM to turbo inlet. And while I am at it, I need a stock fuel pressure regulator too. I basically need to make it look like a stock turbo nissan. Simply taking out the intercooler and routing the pipes directly to the intake does not satisfy them. It HAS to be original. Either that or I need to find a shady smog guy that would let me do it. |
How do they know what's "stock" ? Are they 280zx experts?
(Post 310115)
Neither is a cone filter. The fact that they are not 280zx experts is how I can claim that the Turbo itself is stock. I suppose I can maybe get an aluminum u-bend and scuff it up and paint to look OEM. But I will need an airbox and the hose that goes from it for sure. Edit: That is what I will have to do with the Honda that I have. Get OEM looking parts together. But I knew I would have to jump through some hoops for that one. I did not expect the 280 to be such a big deal to them. The first Smog guy I took it to was complaining about the silicone vacuum hose! Wtf! |
A front mount i/c shouldn't give you any issues since IIRC it isn't an issue with the inspection. The only thing that needs to be present is the stock intake setup. Provided you have the stock intake pipe and the all emissions equipment, you should pass with no problem. If a tech gives you grief over vacuum hose color, I'd suggest finding a different place for your test.
Originally Posted by lifegrddude
(Post 310120)
But none of them want to bend the rules in any way what so ever! The intercooler is a huge problem because they are even giving me crap for non-stock J-pipe. He was even complaining that I took off that valve that ads more air at idle when the AC is running! |
How long ago did you move? if you still have family/friends in raleigh, you could try and reg the car for nc... I know a guy that did that from ny to nc, but had to drive back and forth there once a year
Originally Posted by vg30_s12
(Post 310159)
But not in Raleigh, there I need inspection every year. I will register them with a buddy in Orlando. I hope it won't have to come to that. |
what Part of California are you at right now?
Originally Posted by ib042129
(Post 310166)
That is my fallback plan.
yay California!
Buy a 1972 240Z body in Washington and get to work transferring the drivetrain over. ;) |
Originally Posted by icice9
(Post 310168)
Not that far from you I guess. |
Originally Posted by Bleach
(Post 310305)
yay California!
Buy a 1972 240Z body in Washington and get to work transferring the drivetrain over. ;) I might be okay. Yesterday, I got the stop airbox and piping from Borini. And my Honda passed yesterday morning too even though it has a swapped engine. The tech did not recognize that an H22 does not belong in there. Ha! |
Did you go to a "Gold" station or a "test only" station? I've never heard of anyone failing smog due to a cone filter. Well, you have some other things going on... But to point that out is just crazy.
...a sunroof is undesirable in the S30, not something you want. :D
Well.Today....
I PASSED! I put in the stock pipes (J-pipe and AFM to turbo inlet), stop fuel pressure regulator, and stock airbox. Just in case, I disconnected the wastegate on the turbo so that it never spools up. The car then passed just fine. Now to put everything back. However, I think my distributor is breaking. I will make another tread about it I though. |
Disconnecting the wastegate hose prevents it from opening. If you want the turbo to never spool up then I think you would want to open the wastegate.
(Post 310647)
(Post 310647)
I disconnected the wastegate rod that connects to the valve on the turbo. That way, the little valve always remains open and the exhaust bypasses the turbo. |
