ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   I need some help (https://www.zdriver.com/forums/280zx-s130-forums-77/i-need-some-help-35956/)
zdriverinneed Aug 26, 2012 10:16 PM
I need some help
Ive got a 1982 280z non turbo and i have been working on this beauty for a year now. Ive had the head machined, replaced the clutch , replaced the starter, cleaned the entire upper half of the motor from the piston heads to the distributor cap. i had it running but the Mass Air Flow sensor was shot so i just disconnected it for the time being and got it to start with some brake clean or starter fluid. Then just a couple days ago i bought the mass airflow sensor and now it wont even start. ive tried adjusting the air to fuel ratio but it did nothing. i believe it has something to do with the vacuum system maybe? i didnt have a very clear guide from the book and i dont have the original hood for the car which i was told had the schematics for it. If any of you guys has any idea as to what might be goin on give my a shout because i have 31 days until i ship out for the airforce which leaves me little time to enjoy my pride and joy:042: Thanks!
Jason280ZX Aug 26, 2012 10:32 PM
I don't know much yet about Z cars, but if you want to download a repair manual for your ZX go to xenons130.com and go to reference tab, click your year model and it'll ask to download, i got mine for the 1983 ZX model, i have a chilton book but its been sitting over the years in the car it just started cracking and stuff so i really needed a manual quickly. I hoped this helped at least.
FricFrac Aug 26, 2012 11:31 PM
Yup the FSM from XenonS130 will step you through the whole process. Take your old AFM (the 280ZX uses an Air Flow Meter - not a MAF) and rebuild it. There is a rebuild thread or a link to it here on the forum.
Good job Jason280ZX you're already helping other users on the forum ;) The FSM is THE guide to repairing the car and you'll often see stuff quoted from the FSM in the Chilton, etc repair manuals
Jason280ZX Aug 27, 2012 03:29 PM
No problem dude, i just read your messages and i would see that you give people the xenon website so i just decide to do the same thing to help a bit. I to downloaded it for my 83 280ZX.
rogerz Aug 27, 2012 05:15 PM
you might have flooded it messing around. disconnect the fuel pump. push the pedal to the metal and let it crank a long time (be sure you have a good and fully charged battery). if you get a couple pops then you are on the right track. crank it again with pedal down. no pops reconnect fuel pump and see if she starts normally.
here is my general boiler plate for z's
Clean the connectors for the maf, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
zdriverinneed Aug 27, 2012 10:17 PM
Ok so I checked the battery and it's reading good and the engine isn't flooded I tried what you said to do and it didn't work, sO out of curiosity I disconnected the air flow meter and faked a vacuum leak and started it up with some brake clean then I reconnected the AFM and it drove for a little bit but I could barely touch the gas without te engine dying. I was shifting at around 1200rpm and it wouldn't idle for more than a few seconds. I'm lost again haha
zdriverinneed Aug 27, 2012 10:19 PM
The reply I made on the thread was to you I pressed the wrong button haha
