Help!!!!!!!!!!!
Old Sep 3, 2006 | 12:15 AM
chinesekid's Avatar
Help!!!!!!!!!!!
well.. today i started taking apart my intake manifold.. took off the fule rail, and all wireings, and everything... took off the top intake manifold boit... but i cant get get the bottem!! cant get to it, cant find it, cant do anything!!! HELPPPP... and the i guess "shild thingy" is in between it too... any help please?
Old Sep 3, 2006 | 12:46 AM
jfairladyz's Avatar
grab a 12mm socket and about a 1ft+ of extension snap it on your ratchet and go to town. You'll have to remove the vertical heatshield that attaches to the underside of the intake manifold. The shield that is sandwiched between the intake and exhaust manifolds does not need to be removed. You should be able to fit your hands in there to feel for the bolts and then feed you socket/extension in over the bolt head and just loosen them. You dont have to remove the bolts, just loosen them. Then, after you've unscrewed the EGR tube, the intake manifold will just lift off (as long as you removed all the wires and hoses).
Old Sep 3, 2006 | 11:38 AM
chinesekid's Avatar
how many bolts are on the bottem?? and i cant get the egr tube out.. its like a big as nut on it that i cant break lose...
Old Sep 3, 2006 | 04:09 PM
disconnect the EGR pipe from the big bolt on the bottom of the EGR... or just unscrew it from the manifold. I couldn't get that big huge bolt out of the intake manifold either.
There are six bolts that you need to get out that share the flanges for the intake. You can see the three in the middle hold only the exhaust. These are pictures of my engine out of the car. the turbo and NA have the bolt locations the exact same way.
Attached Thumbnails Help!!!!!!!!!!!-manifoldbolts.jpg   Help!!!!!!!!!!!-manifoldbolts2.jpg
Old Sep 3, 2006 | 04:13 PM
do you still need hood hinges? I have them and a box ready to send them in.
Old Sep 3, 2006 | 04:59 PM
jfairladyz's Avatar
Step One: Soak with PB Blaster. Let it sit, then soak it some more. Put a wrench on the nut and give it a couple whacks with a hammer. If it still wont come loose then give it a lil' more PB and go to town with the hammer on the wrench. Just be care full that you dont let the wrench slip. Round off those edges and you may never get that sucker out. I dont really advise using an adjustable wrench if you can avoid doing so cause its more likely to slip.
Old Sep 3, 2006 | 05:34 PM
FubarI33t's Avatar
Use ALOT OF AZZ too! And soem gloves with carbon fiber knukles might come in handy.
Old Sep 3, 2006 | 06:04 PM
lww's Avatar
lww
Head Muckraker
There's no stuck or rounded nut or bolt that can't be removed with a little MIG... Welder that is!
Old Sep 3, 2006 | 07:23 PM
chinesekid's Avatar
GOT IT ALL OFF!!! pic will be up in a few but im just leaving it all off rite now cleaing everything all off, getting all the dirt off and just trying to clean it all off and cleaning the engin bay... but i'll put it back after its all clean...
