Help!!!!!!!!!!!!!!
Old Aug 28, 2005 | 08:29 PM
jfairladyz's Avatar
Help!!!!!!!!!!!!!!
Ok maybe it's not that extreme but I am really in need of some help with locating a few things here and I know some you have some of this stuff laying around.
I need a vacuum advance unit for my distributor.
I need 2 of the ball bearing inside of the distributor.
I need the plastic piece inside the distributor that holds one set of bearings (not to be confused with the Metal peice that holds the other set) That piece seems to be very brittle.
I've got my distributor layed out and I don't much feel like reassembling it until I can get these parts so I don't have to take it apart and again. The vacuum advance is the least of my concerns right now, it the bearings and the plastic piece that I'm really needing because if I replace the vacuum advance before the bearing, it's just going to ruin the advance unit again. And I can always replace the vacuum advance with the dist. still in the car. So if anyone's got the bearings and the plastic piece please let me know along with how much you want for them.
Oh and by the way it's an NA.
Old Aug 28, 2005 | 08:34 PM
jfairladyz's Avatar
Oh and does anyone know is there are any lighter tension advance springs on the market for the Z. Or know of any swaps from other distributors? Thanks.
Old Aug 29, 2005 | 09:25 PM
Dorifto's Avatar
Jason, I've got a whole ignition system you can pick apart. If it's any easier for you, I could just sell you the whole distributor. I put a new cap and rotor in, and I also have brand new wires and Denso plugs, if you want any of those as well.
Make an offer, like I said, I'm more than confident we can work something out.
Old Aug 29, 2005 | 09:28 PM
jfairladyz's Avatar
Thanks D. You got a PM coming your way for both that and the Diff. in just a minute here.
