got her running again...sorta
Old Aug 26, 2009 | 06:57 PM
captken's Avatar
Well everything went back together ok.
Idles smooth, no leaks, no unusual noises.
When I drove her a Toyota tercel would woop my ***.....slooow excelleration?wtf?
injectors 1 and 6 arent firing.....
Used 9v battery and pigtail to all injectors.
#1 didn't click....new injectors all.
all others clicked.
pulled fuel rail, checked #1 injector, click, click, click...everytime I used the battery? wtf?
pull #1 and #6 plug wires, no change
pull any of the other plug wires, stumble right off the bat.
#1 didn't click when it was installed, did right away out of the car?
any ideas?
Old Aug 26, 2009 | 07:22 PM
captken's Avatar
#1 and #6 injector not firing...
please see my post about got her running sorta...
it has the info, I just fuped the title..I need to be clearer
thanx
kenny and jim bean
Old Aug 26, 2009 | 07:24 PM
skib's Avatar
This facepalm's for you!
how do your injector connector plugs look?
Old Aug 26, 2009 | 07:25 PM
Merged threads. No need for two threads asking the same question.
Old Aug 26, 2009 | 07:29 PM
captken's Avatar
I aint the brightest guy on the planet
but the problem is 1 and 6 not firing....help please nismoPick dude.
thankx.
Old Aug 26, 2009 | 07:30 PM
I would start by answering this question:
Something is going on w/ the wiring, or ecu signal to that sensor. You did the JWT ecu upgrade yourself?
Old Aug 26, 2009 | 07:32 PM
captken's Avatar
brand new...
all injector connectors are new.
as well as
all new sensors everywhere on the engine, including the oil pressure sensor connected to a new nissan oil tube to the turbo.
everything to get a clear signal to the ecu.
Old Aug 26, 2009 | 07:33 PM
You did the JWT ecu upgrade yourself right? Did you use their instructions?
Old Aug 26, 2009 | 10:24 PM
captken's Avatar
yes
and talked to them to confirm every step taken was done right.
kenny.
Old Aug 27, 2009 | 01:42 AM
captken's Avatar
bump
ideas?
Old Aug 27, 2009 | 01:45 AM
skib's Avatar
lolz im the only one up at this time of teh nights yo
Old Aug 27, 2009 | 05:41 AM
If injectors 1 & 6 aren't firing, but you have confirmed that they do pulse out of the car, then I suggest checking continuity on those wires. Get a milti-meter, set to Ohms, pull the injector plug, install a jumper between the two metal connectors inside the plug, and check @ the ecu.
Did you solder the new injector harness? Did you label them all so they don't get mixed up? How about some close up pics of your engine so we can see what's going on?
Old Aug 27, 2009 | 06:28 AM
captken's Avatar
will do
was thinking simularly along those lines. I hate to pull everything out. I had to wire in dropping resistors to all six injector wires, then swap out 2 and 5 per jwt instructions, there might be the problem there since I did that over 2 years ago.
I'll pull the harness and unwrap all the tape yada yada yada.
thanx very much,
kenny jim bean went home.
k85na2turbo
Nov 18, 2012 06:39 PM
Fastezt280
Sep 8, 2011 08:21 PM
StoneJ
Aug 12, 2011 06:41 PM
Ultimate_300Z
Jul 26, 2007 09:22 PM
Riz Z Speed
Sep 1, 2006 06:38 PM
