Got any simple mistakes?
Old Aug 25, 2006 | 03:25 PM
thxone's Avatar
Question Got any simple mistakes?
Every since I changed my oil, my oil pressure has been low. Sometimes when I take turns the pressure would drop to near zero!! Well I remembered that when I changed the oil and put on the new filter...I didn't put any oil in the filter. Well that was like a month ago and I just figured my gauge was messing up. Well I decided to check my fluids today and I noticed my oil was almost a qt low, now when I checked it when I first did my oil change it was fine...then again I didn't start the car or I would have known the oil filter also needed oil in it as it said "4.75qt WITH FILTER" It either slipped my mind or I forgot to put in the fifth qt...I did have an extra qt sitting on my porch...it's the simple mistakes I guess...it does seem alot better now.
Old Aug 25, 2006 | 07:25 PM
FubarI33t's Avatar
i never fill filter when i change. Motor does that for me during start. Maby the oil is just slushing around. My guess
Old Aug 25, 2006 | 08:49 PM
thxone's Avatar
Well what I did was only put 4 qt's in, so when I was driving, it filled the oil filter which lowers how much is in the pan by the amount the filter holds. Now I have the extra qt in there and the level is good. So insted of 4.75 qt's I have 5 qt's in it.
Old Aug 25, 2006 | 08:56 PM
jfairladyz's Avatar
Unless the filter has an anti-drainback valve built into it then it really doesnt matter if you prefill it or not. Cause if it doesnt then all that oil you just put in the filter just drained down into the pan. And thats what doesnt spill out when you're trying to screw the filter back on. Fram makes an expensive filter with this feature and most OEM and other filters have it. If the filter doesnt have this then everytime you shut the car off the oil drains back to the pan. So installing a filter dry is just like shutting your car off: no big deal.
I oil the filter seal and then screw it on. Add my oil to the engine then crank it with the ignition disabled til I have pressure. Then I check the oil level and add if necessary. Hook the ignition back up and let her atleast reach operating temperature. Done deal.
Old Aug 25, 2006 | 10:09 PM
thxone's Avatar
Fram makes an expensive filter with this feature and some OEM filters have it.
I myself am not the biggest fan of fram filters. Here is a link I found about a year ago on oil filters...interesting reading and informative observations. Lots of info on what is and isn't in a good filter.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Old Aug 25, 2006 | 10:20 PM
jfairladyz's Avatar
I did a little digging around and it seems pretty much all oil filters are coming with the anti-drainback valves now.
Old Aug 26, 2006 | 12:07 AM
lww's Avatar
lww
Head Muckraker
Pre-fill them. Not because of the increased oil capacity, but because it get's oil to the engine faster on the first start-up.
When the filter element is saturated with oil prior to start-up, it will have no room to absorb any additional oil, and it will flow to the bearings faster.
When the filter element is dry, it has to become saturated before oil begins to pass through it.
It's such a small thing to add to the potential longevity of your motor, it's a small price to pay for peace of mind.
Old Aug 26, 2006 | 12:16 AM
Carl's Z's Avatar
That makes a lot of sense, and is good info!! BTW, I went from Fram to Purilator, just because of the crap I, and I'm sure most of you, heard about Fram's secondary filtration system problems...
Old Aug 26, 2006 | 05:03 AM
FubarI33t's Avatar
My red oil light went off yesterday while trying to start it. even built up a lil pressure. Guess that's a sighn you've held the starter down to long.
Old Aug 26, 2006 | 07:51 AM
i hear fram is good for breakin in a new motor though, past that i dont know any one (that appreciates cars) that would use a fram oil filter
Old Aug 26, 2006 | 08:43 AM
FubarI33t's Avatar
I have used fram on my 03 ranger ever since i bought it new off lot. 116K and still kickin like the day i first drove her home
Old Aug 26, 2006 | 10:25 AM
RodMoyes's Avatar
Doesn't post much...
You want a simple yet funny mistake???
Having the Key in the "ON" position so you can listen to the radio in the car while changing the FUEL FILTER.... Nothing quite like a sudden 6 foot high guyser of gasoline shooting directly at your face when you pull the hose off!
Been There
Done That
Rod.
P.S.
I guess that's not as bad as the nameless other "ZDriver" who recently snapped both lower ball joint bolts off in the spindle because they forgot about the "Lefty Loosey, Righty Tighty" Rule!!!!!
Old Aug 26, 2006 | 01:50 PM
turbot5's Avatar
if two wheels apply..
I think I have the world record of dropping motorbikes in my own driveway..nothing fancy, just arrive turn off key, senior moment n voilà! death horse under my legs
Old Aug 26, 2006 | 02:21 PM
i got my hand stuck between the fuel rail and the valvecover when doing the intake job once, my dad had to come and rescue me and unbolt the valve cover.!!
Old Aug 26, 2006 | 02:38 PM
thxone's Avatar
How about having the front end of my Fairlane on jack stands while doing about 5 different jobs on the car at one time then turning the key while it is in first gear!!! The car would desel just enough to not stop jumping forward and the brakes for the most part were useless...had to slam it in park after about 30 feet...once I stopped freaking out and noticed it was in gear
Old Aug 26, 2006 | 07:32 PM
3XAZOWNER's Avatar
My son, a friend of his and myself were swapping out the motor from my parts car! No one thought to pull the battery! Here it comes....
A spark from removing the wire to the alternator, which was done after the gas lines were removed and the car went up in flames. I had my back turned to the car and all i heard was OH **** ! Before i could run back to the car, the friend had doused it in antifreeze and put it out. Now i follow the rule of disconnecting the battery, almost no matter what i am doing. Too bad we didnt have that on video, that would have been funny watching our reacton!
My son just ran in the house. When he came back we were all laughing at him. I asked him why did he run? He said someone had to be there to tell the coroner what happened!
Old Aug 27, 2006 | 03:17 PM
thats the first step in the haynes manual for ANY job, is disconnect the neg. terminal.
Old Sep 3, 2006 | 07:14 PM
wreckedj30's Avatar
No Club Love
what about getting your hand caught under the hood tension rod thats worse or almost cutting your hand off tring to remove an engine, the bolt on the head wasn't fully tightened and it swung at me, v8 390 thunderbird motor it hurt.
Old Sep 3, 2006 | 07:21 PM
jfairladyz's Avatar
I removed the hood release cable but left the latch installed so when the wind blew the hood shut it was stuck that way I had to unbolt the front of the hood and squeeze in there as far as I could to get at the bolts that hold the latch in place and unbolt that. If I would;ve been even the slightest bit overweight there would've been no way I could've gotten in there. Luckily I'm thin with long arms or that could've been ugly.
Old Sep 3, 2006 | 09:39 PM
lww's Avatar
lww
Head Muckraker
Oh... J, I thought your avatar was a self portrait!
Old Sep 3, 2006 | 10:04 PM
wreckedj30's Avatar
No Club Love
yeah same here working under the hood out of no where mean gust of wind luckly, that hood isn't as heavy as my old ford or that might of really hurt.
Old Sep 3, 2006 | 11:07 PM
good thing your head might be thick too!! j/k
Old Sep 3, 2006 | 11:22 PM
wreckedj30's Avatar
No Club Love
only a little but don't make fun of me at least im not canadain j/k
Old Sep 4, 2006 | 12:42 AM
lww's Avatar
lww
Head Muckraker
DOH!!! You hoser...
Old Sep 4, 2006 | 08:38 AM
dont make come down there
