fuses....help?
Old Feb 15, 2005 | 10:02 AM
DynamicJ's Avatar
Z8 driver
fuses....help?
Okay, I've had my Z for about 3 weeks now, and this morning was the 5th time I have changed the windsheild wiper fuse. Anyone know why this ONE fuse would be blowing constantly? The other fuses are fine... Also, the wiper fuse was blown even when I got the car... Thanks,
Jason
Old Feb 15, 2005 | 10:30 AM
icice9's Avatar
Super Siver & Black Stud
you might have a short somewhere on that circut..
Old Feb 15, 2005 | 03:32 PM
theramz's Avatar
I have a present for you...
her are some possible causes; a direct short to ground which will blow the fuse in a few seconds, the linkage arms to the wipers are binding causing the circuit to overload, or the motor itself is worn out. You can remove the cowling between the hood and windshield and disconnect the wiper arm linkage and try to operate the wiper motor with no load. If the fuse still blows try cleaning the motor out. Inspect the wiring for shorts. Disconnect the motor completely and if it still blows then you have a short under the dash. What ever you do, don't increase the size of the fuse.
Old Feb 16, 2005 | 10:33 AM
DynamicJ's Avatar
Z8 driver
source of the problem... I found out today that every time I touch the switch for the rear wiper (which doesn't work) the fuse pops... any help?? THANKS!
Old Feb 16, 2005 | 01:34 PM
Unplug the rear wiper switch.
Remove the rear wiper arm.
Old Feb 16, 2005 | 06:20 PM
lww's Avatar
lww
Head Muckraker
Bleach, you're so practical! Obviously not a fan of the rear-wiper!
Old Feb 16, 2005 | 10:40 PM
well, yes.
I'm going to remove the rear wiper motor from my car just because it is ugly and we don't get along.
Old Feb 17, 2005 | 04:27 AM
DynamicJ's Avatar
Z8 driver
haha, works for me bleach.
Niku-Sama
Mar 16, 2008 06:17 PM
Skully
Sep 30, 2003 05:13 PM
hadez
Dec 11, 2002 07:26 AM
junior
Jun 7, 2002 09:42 PM
cassarly1
May 21, 2002 02:07 AM
