FM Modulator - 280zx
If you like the stock stereo but need your iPod, you got to get one of these Audiovox FM Modulators (fmm-100). It plugs into your antenna wire and lets you hardwire tap into your current audio system. On my Z it took a full day pulling the radio and deciding where to install. I ended up using a wire tie and tucking it behind the passenger kick panel, it fit just fine (see pic below) and there was enough reach for the antenna and for power/ground. There is a switch the you use to switch from the radio to the modulator and I mounted that next to the cassette player in the dash (see pic) the switch BTW has a red tip, what are the odds! hehe So cool man! I ran an RCA-to-mini 8 mm patch cable out behind the radio and out in front of the shifter, not sure where this will end up maybe in the center console, totally stealth!
Link to flickr
Link to flickr
Link to flickr
Link to flickr
koprutzxt
Apr 29, 2012 06:34 PM
