ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   Even more issues (https://www.zdriver.com/forums/280zx-s130-forums-77/even-more-issues-21215/)
skittle Dec 21, 2006 01:47 PM
Even more issues
Well i changed out the connectors for the temp thingies on the front of the engine. I went to try to start the beast and guess what NOTHING happened. I checked all of the connections and made sure my battery was charged. I disconnected the starter and when I turn the key it makes noises. Once I re-connect it I turn the key again and nothing happens. Its acting like the battery is dead...
My guess is the alt is bad now...
Am I close?
thxone Dec 21, 2006 02:01 PM
The alternator should not keep the car from starting or running, if the battery is charged a car will still run, that is one of the things the reserve capacity on the battery is for...with no alt the car should drive for 10-20 minutes on just the battery, after that you are screwed unless you limped the car to an auto parts store. I would look elsewhere for the culprit. Edit: like the solenoid on the starter itself, could be fried.
NismoPick Dec 21, 2006 02:10 PM
If you're not getting any power (like the lights / accessories won't turn on) check your battery voltage... and terminal connectors.
skittle Dec 21, 2006 02:37 PM
Ok Ok I Get The Dumb Ass Award For Today I For Got To Connect To Coil To The Dizzy... Lol But She Is Still Smoking Like An 80 Year Old
thxone Dec 21, 2006 02:47 PM
Ahhh yes, the coil...good one, lol.
skittle Jan 8, 2007 02:01 PM
well i think i might have found out my running rich issue I hope... I got a new fuel pressure regulator and tryed to install it. I found out I need to get new fuel line hoses the ones i had would not come off so I had to cut it.. lol I hope this fixes the issue.
On a side note I'm selling my psp so i can get either a;
1. megasquirt
or
2. a pallnet fuel rail and a better exhaust...
opinions???
Bleach Jan 8, 2007 02:10 PM
is a PSP really worth $300+???
skittle Jan 8, 2007 02:45 PM
well not just the psp it has alot of extras and i have more saved up as well...lol
DGriffin Jan 8, 2007 02:51 PM
1. megasquirt
or
opinions???
Can't you use megasquirt and tune your fuel delivery to get rid of your running rich problem? I dont know that much about Megaquirt but I beleive you can tune it.
skittle Jan 8, 2007 03:58 PM
Yeah I Can, It Gets Rid Of The Afm And The Ecu. But At 300+ For The System Its A Lil Much Compared To The 150 For The Fuel Rail
