electrical problems wtf
Old Feb 22, 2004 | 11:06 AM
cerealkilla's Avatar
i just installed a stereo system in my ride and i dont think the car likes it. using the wiring diagram and running new wires has the stereo working fine.........BUT now when i open any door of try to use my map light the digital clock cuts off and the alt. gage goes to zero. and none of the lights come on. except the door open light in the instrument cluster. has anyone had this problem before or any suggestions? ps all fuses are good
Old Feb 22, 2004 | 06:56 PM
FastZ's Avatar
Make sure all your stock wires behind the radio are not touching. It is a good idea to tape them all so they can't make contact with anything.
Old Feb 22, 2004 | 07:04 PM
did that already still does same thing
Old Mar 10, 2004 | 06:47 AM
ok so if you look in the dictionary under dumb *** you will see a picture of me.
i found out why my car was acting up. it turns out that a fuse was bad. see i was checking the fuses with a dmm so i wouldnt have to remove all them. but that circuit grounds on both sides so i was getting continuity across the fuse. yesterday i physically removed all fuses and checked them and low and behold there was a bad fuse. replaced it and it all works good now. so a lesson in troubleshooting is the rule of the day..
licketysplit
Feb 4, 2014 08:06 AM
lostdriver
Feb 2, 2014 01:40 PM
Jose Rios
Oct 27, 2012 08:44 AM
c-los.p
Oct 3, 2010 06:22 PM
Jays_Z
Aug 22, 2005 08:25 PM
