electric window problems
Old Jun 29, 2009 | 04:41 PM
Timc.king01's Avatar
I was wondering if anyone out there knew what the problem could be with my windows i got the car about a month ago and both windows for some reason do not work anyone have any answers thanks
Old Jun 29, 2009 | 06:41 PM
njgheewala's Avatar
Dunkin' Donutz
You gotta give more info on this...what is it doing,? do you hear the motor? You can also turn the light in the dome and see if it dim when you press the button.
Old Jun 30, 2009 | 07:20 AM
kittyz's Avatar
fuses. try the basics first.
Old Jul 3, 2009 | 08:27 PM
rogerz's Avatar
Grumpy & Helpful
as above probably not getting power. the door switches to control the window may be bad but probably not both of them so I would suspect primary power loss. pull the door panel and make sure everything is not rusted together. after you check the fuse see if getting power to the door switch with a vom. fuse box itself is known to go bad so you might inspect that.
lts70
Dec 22, 2010 02:04 PM
Niku-Sama
Sep 28, 2008 12:32 PM
skupy
Nov 14, 2005 01:42 PM
kraftor80
Nov 2, 2004 09:23 AM
Las VegaZ
Aug 31, 2004 04:00 AM
