Door locks
Old Jun 18, 2014 | 08:58 PM
GNRick's Avatar
Door locks
I used to have an 83 Z and when I locked the driver's door the passenger door locked too. I recently bought an 82 and the pass. door does not lock with the driver's door. Is this normal or is something not working? Thanks.
Old Jun 18, 2014 | 09:10 PM
PredatorZ's Avatar
Base model
Do you have power locks ? probably not, the GLL package had electric door locks, power mirrors , power windows, which most base models don't have. You can figure out what options your car came with by decoding the Vin, post it and if you like Ill do it 4 u. Al those power options added a lot of weight too. Looking under the drivers seat out of my 86T, it has at least 3 motors, and all kinds of gears and crap, it weighs a ton. So performance wise, the base model is lighter !
If you do have the power options, then you have a bad wire, switch or fuse.
Old Jun 18, 2014 | 09:21 PM
GNRick's Avatar
Gll
I do have power mirrors and windows, rear wiper and front headlight washers (missing washer reservoir however). Here is the vin: JN 1CZ 06S 7CX 6 00685
If the p/s door lock should work, should I remove the door panel and check for power at the lock? If there is power, then would the lock motor be bad? Or should I start with the d/s door lock to make sure there is power going to/from it? Thanks PredatorZ.
Old Jun 18, 2014 | 10:22 PM
PredatorZ's Avatar
Check the connections
You could just have a corroded connection in that door, pull the door panel and check out all the connections, clean them if needed, I would check the connection at both door lock switches also.
Old Jun 19, 2014 | 06:42 AM
Pull out ye ol' multimeter and check the wiring. I'd start with the door lock relay.
Old Jun 19, 2014 | 08:51 AM
PredatorZ's Avatar
There is a model designation number, not the Vin, should start with HL or KH that will have a break down of your options, post that number and Ill figure it out. The tag on my 81 was next to the battery on the firewall
Old Jun 19, 2014 | 12:42 PM
GNRick's Avatar
Khl
KHL GS130 JAT UBC.......thanks Predator!.....oh, it was built in plant X....is that anywhere near Flint?
Old Jun 19, 2014 | 01:00 PM
GNRick's Avatar
issues I still need to address....float in washer reservoir, no back up lights, and no power doorlocks. Spent a couple hours scraping rust and applying POR-15 today. I put the car on jack stands and it looks like I might have some brake fluid leaking in the rear.
Attached Thumbnails Door locks-hpim2807.jpg   Door locks-hpim2810.jpg   Door locks-hpim2811.jpg
Old Jun 19, 2014 | 01:09 PM
PredatorZ's Avatar
Non-Cal
Non California car, L28ET, 3n71b auto trans, r200 rear, p205 / 60R 15 standard tires
K - T-tops
H - L28
L - Left hand Drive
G - 2+2 (is this correct ?)
S130 - Model
J - Grand Luxury
A - Automatic trans
T - Turbo
U - USA model
B - Power Steering
C - Air Conditioning w/ manual Control
that's about all the info I can squeeze out of that !
All the information I am using comes from the general Information section of the factory service manual.
Old Jun 19, 2014 | 01:16 PM
PredatorZ's Avatar
Pics yea !
thanks for the Pics, she looks nice, and you are fully louvered out, Jamal would be jealous, I know he was looking for the rear louvers for a 2+2 for a long time, I think he finally found one, but I don't think he has the side ones, very cool.
Old Jun 19, 2014 | 04:26 PM
GNRick's Avatar
K - T-tops
H - L28
L - Left hand Drive
S130 - Model
J - Grand Luxury
A - Automatic trans
T - Turbo
U - USA model
B - Power Steering
Yes it is a 2+2. Thanks for the info. So I should have power locks, correct? The wife of owner number 4 wanted black trim parts which is why the door arm rest is black, as is the visors and steering wheel. I've already put back the red steering wheel. Anybody need black trim parts?
Old Jun 19, 2014 | 04:27 PM
GNRick's Avatar
Are the louvers rare? Not made anymore? Are they different for 2+2 than for coup?
Old Jun 19, 2014 | 04:33 PM
PredatorZ's Avatar
Yup
you have the GLL all power dohickeys, so now it is just a matter of tracing the issue down, its a switch, corroded connection or a bad relay ! The fsm shows all the locations of the relays, shouldn't be too hard to find. But if you run into a snag and can't find it , Ill track it down, I have every fsm that's available for Z's with countless hours studying them, so I know the Nissan manual format and where to look, usually ! I learn so much just doing research for others, and I am on holiday, burning off my vacation pay and wrenching on my zx as much as possible.
Old Jun 19, 2014 | 04:52 PM
PredatorZ's Avatar
Ya all different
Apparently not many people opted for the 2+2 louvers and as far as I know its a hard to find item now, so you are very lucky, the rarest trim option is the carrera trim bar, not sure on the name, but it takes the chrome piece on the side window and carries it over the roof, ill post a picture of an example. better pics of the bar lower in the post, I did ask him for better shots to document them.
pics on this zdriver page
https://www.zdriver.com/forums/280zx...inished-37533/
Old Jun 19, 2014 | 05:04 PM
Old Codger's Avatar
I don't remember now where I did buy the the rear louvers for my 2 + 2. But I do remember I wanted them to keep the sun off the back storage area...And I kind of like their looks!!!!!!!
I can't remember...you know C.R.S......but I think where ever it was, they also had the side louvers, but I thought at the time, that's a little too much.
Old Codger
Old Jun 19, 2014 | 09:04 PM
GNRick's Avatar
There are several people selling used rear louvers on ebay. Here is a new one for $326: Willpak 10534 Aluminum Rear Window Louver | eBay
Old Jun 19, 2014 | 09:06 PM
GNRick's Avatar
I would think a competent restoration shop could fab up a stainless steel piece if they had a good picture with dimensions.
Old Jun 20, 2014 | 07:41 AM
PredatorZ's Avatar
its possible
For one, that ebay ad groups all the louvers into a single group, as if 2+2 and coupes were the same, and still, what I was talking about was a Nissan part, anything other than that is just chinese crap ! You can bolt on or have made almost any part(if price is no option), short of the rubber door seals, which seems impossible for someone to reproduce, But it's not the stock piece, which has a look all it's own. I wouldn't trust a part that shows a picture of a mustang to sell a part for a Nissan. If they were really serious, they would show the louvers on our cars ! There is a niche group of companies trying to make good quality replacement parts, when shopping I try and use these people, so I support them supporting us !
Old Jun 20, 2014 | 07:51 AM
PredatorZ's Avatar
Roof piece
If we could find someone to reproduce the stainless roof piece, I would buy one. Would rather have an original, which are available used. I would almost be willing to buy one from ZSource, send it to a fabricator and allow them to make an exact copy.
Nissan 280ZX Targa Strip, Datsun 280ZX Targa Strip, 1979-83 - Z Car Source
289$ bones to have the honor. I had my eye on a fairly nice zx that had the roof trim, but it sold.
Old Jun 20, 2014 | 09:08 AM
borini63's Avatar
Do you need one?
I have Two just sitting and waiting for the lucky new owner!!
Also I just got some side louvers for my 2+2 and I found a rear louvers not long ago....
Amazon Amazon
Old Jun 20, 2014 | 11:10 AM
PredatorZ's Avatar
Targa bar
What are you selling your targa bars for ? Zsource wanted a ton( 289$). I am broke atm, but very interested. I am going to sell off some of my z31 stuff, digital dash etc,,
Old Jun 20, 2014 | 02:52 PM
borini63's Avatar
How about $150 shipped,just for you.
Let me know when you are ready.
Old Jun 24, 2014 | 08:40 AM
GNRick's Avatar
Well, getting back to the door locks. From the fsm I checked the door lock timer and it tested fine. I also checked voltage at the plug going to the timer and I think I have low voltage there when I lock/unlock the driver's door. Then I pulled the door panel off to look at the electrical solenoid. It is mounted inside the door. It looked like removing it was beyond my capabilities so I just left it alone. Fortunately I can easily lean over and lock/unlock the passenger door.
Maikel C
Jan 12, 2015 07:12 PM
thxone
May 16, 2006 01:50 PM
1stz32
Apr 25, 2006 01:33 PM
Cw2435
Jan 15, 2005 08:34 PM
duckyz
Aug 10, 2004 07:53 PM
