Don't belong
Old May 19, 2005 | 05:14 PM
flightforlife07's Avatar
Don't belong
Hi, know this is the wrong forum and site all together to be asking this but I need help. My 1987 toyota pickup (daily driver) is suddenly giving me ****. I started it the other day and it started smoking (white) it only does it for a second or two and then goes away until I restart the truck. Then yesterday I was at my friends house and I started it and it smoked a combination of white and black smoke. I'm sixteen and don't know wut to do. I need to get my truck smogged this tomorrow so please if anyone knows its greatly apprecitaed is an 87 toyota pick-up 4cylinder and carbeurated
Old May 19, 2005 | 07:17 PM
DoTheDrew888's Avatar
I think your piston rings are shot. When the engine is cold the piston rings will shrink and have small gaps which will allow a small amount of oil to burn. That is the cause of the white smoke. Once the engine warms up the rings expand and create a seal again. I don't know if you are going to be able to pass inspection but just make sure its well warmed up when you take it.
Old May 19, 2005 | 11:16 PM
whyfeel's Avatar
Good luck smogging that engine, that could be extremely difficult, FYI.
Old May 24, 2005 | 01:33 PM
Despite all the negative things going through my head lately I went and got my truck smogged.... It seems to have almost completely stopped smoking and ran erally good for the smog station. It passed running very cleanly the guy said. I think my carb needs adjusted because its running rich but it passed! Thanks guys
Old May 24, 2005 | 10:11 PM
Captain caveman's Avatar
Maybe you should use a motor oil of a higher viscosity if you have bad piston rings, that'll help prevent blowback.
Did you run any compression tests?
Old May 25, 2005 | 06:47 AM
yea when I adjusted my valves I did a compression test they were all at 180 psi except one cylinder was at 160 or 170. I think part of the problem is flooding the cylinders when it starts because its carbeuratedbut I'll consider that when I change my oil next time thanks.
markmbsc
Feb 2, 2006 08:10 AM
Skully
May 13, 2005 09:09 PM
