Coolant Vanishing at Rate of Approximately 1 Quart Every 2 Days
Old May 26, 2007 | 09:30 PM
crowthma's Avatar
So, I just got my first Z last weekend and am attempting to resolve a few of its issues. The coolant system is my number 1 concern at present because the temp sender has failed and I keep losing coolant at the rate of approximately 1 quart every 2 days. I've tried to find a replacement sender, but no one has one that looks like the one that's in there (with the little wire hanging out of it). Does anyone know if this one might work http://cgi.ebay.com/ebaymotors/ws/eB...5091&rd=1&rd=1? As far as the coolant loss goes, I've had the system pressure tested and nothing's wrong there. So, it must be getting too hot and evaporating? I'm not sure. Please help!
Old May 26, 2007 | 09:33 PM
That sensor on ebay is what you need. As for the loss of coolant, if you're not leaking it, you're burning it... which means you have a leaking / blown head gasket. Those are always fun.
Old May 26, 2007 | 10:07 PM
crowthma's Avatar
What are some other things I can do to test and see if my head gasket is blown?
The guy I bought the car from said he just rebuilt the engine and I'm inclined to believe him. Wouldn't it be spewing white smoke if the head gasket were blown?
Old May 26, 2007 | 10:27 PM
Not always, but white smoke is a good sign of a blown hg. There's only so many places coolant can go... and if it's not leaking onto the ground, it's narrowed down quite a bit. Check all the coolant lines & connections... check the radiator fins & also the cap.
Old May 27, 2007 | 11:01 AM
crowthma's Avatar
Thumbs up I think I may have found it...
I checked again after a short drive and there was some moisture on the hose connection right above the alternator. I moved the clamp up toward the fitting some more and really cranked down on it. I guess I'll have to drive it some more to find out if the leaking stopped. Oh the torture!
Old May 27, 2007 | 01:45 PM
Let's hope that was the prob....
Old May 27, 2007 | 02:23 PM
crowthma's Avatar
So far, so good!
Just went for a quick drive and checked the coolant levels when I got back. The resevoir is actually more full than when I started and the area around the clamp I tightened is bone dry. The hose looks new. So maybe when the last owner replaced it, he just didn't tighten it enough. We'll see.
Old May 27, 2007 | 02:41 PM
frank280zx's Avatar
Euro Z King
From: Utrecht The Netherlands where owning a car is a CRIME!!
That sounds plausible enough ! nice that somethings are an easy fix
Old May 30, 2007 | 08:45 PM
duckyz's Avatar
Ain't it the truth!!!
Old Jun 15, 2007 | 06:52 AM
BigEkak1941's Avatar
Usually a quick check of the oil (if grayish then you have water in the oil) will tell you if you have a leaky head gasket, but from what you wrote additionally it appears to be a loose hose clamp. Most of the time it's the little things that cause the most problems. Good Luck
Old Jun 15, 2007 | 08:41 AM
RodMoyes's Avatar
Doesn't post much...
Sounds like you may have found the problem.
Good luck.
Rod.
Old Jun 15, 2007 | 05:01 PM
crowthma's Avatar
Good luck.
Rod.
Indeed. That ended up being the problem. Now, however, I've got a small leak by the radiator drain **** - probably a result of having drained it so many times in failed attempts to replace my water temperature gauge sensor. But that shouldn't be a biggy. I'm just waiting for it to cool down now so that I can attempt sensor replacement one last time.
Zombie
Nov 10, 2011 12:52 PM
js9krcr01040
Sep 22, 2006 07:24 AM
Riz Z Speed
Polls
37
Sep 12, 2006 02:39 PM
rxKaffee
May 22, 2006 09:47 AM
phsharkey
Mar 31, 2003 11:07 PM
