Coolant part identification
Old Dec 17, 2012 | 05:47 AM
corbith's Avatar
I developed a small coolant leak from the part highlighted in the picture but can't seem to find the name of the part in the FSM, RockAuto or TheZstore's websites. Can anyone help me identify this part and where I might find one?
Old Dec 17, 2012 | 07:24 AM
icice9's Avatar
Super Siver & Black Stud
its a valve regulator heres the part number 27188-Q0105 should cost around $11.00 - $15.00
Old Dec 17, 2012 | 07:41 AM
corbith's Avatar
Thank you! Is this a part that commonly develops a leak or is a sign of a bigger problem? Just trying to understand if there is anything else I should be looking for while changing this part.
Old Dec 17, 2012 | 08:14 AM
icice9's Avatar
over time it will leak.. It's a pressure relief valve that allows a bypass from the lower portion of the thermostat (back of the head) to the pump inlet when the engine is brought up to higher rpms before the engine thermostat is open. your leak can either be from a worn out O ring inside the valve or just corrosion. its funny cuz mine just started leaking a few days ago and im about to order the same part..
Old Dec 17, 2012 | 09:22 AM
corbith's Avatar
I just ordered one from Courtesy Nissan at lunch, they didn't have one in stock but said they can have one in and sent out to me on Wednesday. It looks to be a fairly simple repair but is there anything I should be aware of while replacing?
Old Dec 17, 2012 | 09:28 AM
icice9's Avatar
not really... but it should be a good time for you to flush your cooling system if you haven't done so yet. i know i will be..
Old Dec 18, 2012 | 04:21 AM
corbith's Avatar
I plan to do the same, actually was about to change the plugs and wires when I found the leak as I'm doing a tune-up. Where did you find that part information, I couldn't find anything in the FSM other than the picture?
Old Dec 18, 2012 | 07:26 AM
icice9's Avatar
Google is my friend!! lol
Old Dec 19, 2012 | 04:44 AM
corbith's Avatar
LOL, yes it is... I was just unsure what the part was even called. Love your car btw, I'm going to resume installing that same body kit once I get this part installed. Got derailed by replacing all the brakes. Any pointers for installing the front portion? I have the side skirts on but the front is giving me a very hard time.
91Z32
Dec 4, 2021 02:28 PM
professor229
12
May 14, 2015 08:57 AM
Phram1
Feb 23, 2013 05:30 PM
dukesplace
Sep 24, 2008 04:34 PM
zpeedracer25
May 27, 2003 05:14 PM
