connecting boost control
just want to be sure i did it right does some one have like an image of how to connect the manual boost control.. cause i open the boost control and nothing happens..
Lots of install instructions on the intrawebs... here is the main one from AtlanticZ.
FYI... "Opening" the boost controller won't increase the boost. You have to CLOSE down the boost controller, not all the way, but you have to reduce the boost to the wastegate, so it delays the port from opening. :D http://www.atlanticz.ca/zclub/techtips/turbo/index.html http://www.atlanticz.ca/zclub/techti...ed280turbo.jpg |
good to know thanks alot
Also, do you have an aftermarket boost gauge? You will need one to properly adjust a MBC... otherwise you won't know how much it's boosting.
Secondly, MBC's have more cons than pros. Actually, the only pro is that it's cheap. They are prone to boost spikes, and are cumbersome to adjust. Electronic Boost Controllers are very accurate, and you can adjust from the cockpit while driving (nice for when you need "a lil extra boost in a hurry"). |
yea i do have an aftermarket boost gauge.. and do u know where i can get an electric boost gauge
Electronic boost gauge or controller?
www.ebay.com :D Stick w/ name brands like HKS and GReddy. http://cgi.ebay.com/ebaymotors/JDM-H...Q5fAccessories I have an HKS one, and love it: http://memimage.cardomain.com/member...58_99_full.jpg |
and the electric boost control connects the same as the MBC with the hoses and just power and ground
In a nut shell, yes.
