compressor bypass valve.
hello,
from J pipe, how should I route the bypass? I am not using the aac. I think the J pipe went to it. I have a bosche type bypass, like jim wolf sells. help please. got my panasports and re-11s. 225-50-16. tight fit on front. pics later. kenny. |
compressor bypass valve? do you mean the pop off valve?
nope
pop off is different. my car doesn't have a compressor bypass valve installed. someone said it should go to pvc as a joke. Factory, it goes to the aac valve, I think. Got rid of everything on the manifold, per fubar....to clean up the intake. thanks, need to plumb up jpipe, gotta spark plug wedged in there for now. kenny. |
1 Attachment(s)
^^^ That didn't really clarify anything... so, tell me, #1, 2, or 3? Sounds like you are talking about #1, but a bypass valve would either be the wastegate or blow off valve...
Attachment 20829 |
turbo question
wastegate actuater plumbed to intake manifold instead of compressor outlet.
vaccum line to actuater collapses with the manifold vaccum. turbo boost is limited to pop off valve on manifold. [I think] question: When boost happens, will it work to open up the collapsed vaccum line? I cannot tell blipping the throttle, standing next to car. Actuater does not move, however, I know it's boosting. Want to up the boost. thanks in advance. |
I'm so ****ing confused right now, even obama is running circle around my intelligence...
jpipe
guys, the stock jpipe has a hose fitting on top. From what Ive read from searching forums, this is the compressor bypass valve.
I cleaned up the intake manifold and don't have the aac valve, which I believe it was connected too. I just need to know where to run a hose from the hose fitting on top of the jpipe to the intake. sorry if im confusing yall. The j pipe runs from the compressor housing to the 240sx throttle body, it has a wrinkle black paint finish to it, shaped like...well...a..."J" I don't see it in your excellent pics nismo. kenny. |
Originally Posted by captken
(Post 269279)
vaccum line to actuater collapses with the manifold vaccum. turbo boost is limited to pop off valve on manifold. [I think] question: When boost happens, will it work to open up the collapsed vaccum line? I cannot tell blipping the throttle, standing next to car. Actuater does not move, however, I know it's boosting. Want to up the boost. thanks in advance. Answer (in another question)... have you tried getting vacuum likes that won't collapse? |
(Post 269282)
I cleaned up the intake manifold and don't have the aac valve, which I believe it was connected too. I just need to know where to run a hose from the hose fitting on top of the jpipe. sorry if im confusing yall. kenny. Pick #1 #2 or #3 from that picture I posted. |
(Post 269283)
Merged threads... no need for 2 threads when you already have a new thread.
wrx/sti's use by pass valves, check with the subaru peoples.
dont ask me i have a turboed subaru but i no nothing about how the turbo works in it other than it spins pushing air into it....some how...its kinda funky |
jim bean
(Post 269285)
Apparently Jim Bean is present and not captken tonight. :paranoid:
Pick #1 #2 or #3 from that picture I posted. Is not present. I think, from your pic, #1. However, where is the Jpipe? I cannot tell. sorry, kenny. |
I'm not sure why you are making a big deal about the j-pipe, but it wasn't installed when I took that pic. Here's a "complete" one for you:
https://www.zdriver.com/forums/attac...7&d=1251434585 |
post a picture
1 Attachment(s)
I'll post a picture tomorrow.
Yes, the 280zx turbo has a compressor bypass, it went to the aac valve. I cleaned up the intake manifold and now the jpipe fitting has no place to go....! phone camera picture of car. kenny |
man... it's like pulling teeth to get anywhere in this thread.... :wasted:
I see
So I have to plumb it back to the intake manifold. Should I reinstall the aac valve and do it your way, or will the avaliable vaccum ports support the volume of air?
kenny. |
hey
(Post 269292)
If I read your first post right, you can use the nipple on the J-pipe for the bottom of the bosch bypass valve, and use the recirc part to vent back into a tube before the compressor. It's not pretty, but it will work. Otherwise, I'm misreading what you're trying to say. The Bosch bypass valve is only good to about 14 psi before it leaks btw. The Porsche style ones can handle a bit more boost, but not much.
thank you very much.
Originally Posted by lifegrddude
(Post 269392)
I installed the bosche bypass valve just off the jpipe. I am currently venting to atmosphere. Satisfying phooshe...! sound everytime I lift off throttle, it operates everytime I lift off throttle, even a little bit, you hear it, so I know the compressor is spinning freely on partial and closed throttle. I will plumb it up to intake later. Problem is, 2 turbo cars and one complete engine in parts! No static model for me to reference. thanks for your reply, kenny. |
(Post 269544)
Is is plastic? Most of those plastic bypass valves leak boost. |
all that money into that cat. just get a good aftermarket release
we did the intake maniflold cleanup sticky.
(Post 269562)
you created and was posted as a sticky, Unfortunately, I think it does not apply to the turbo car. kenny. |
advise
(Post 269562)
