CHTS compatibility?
Is the CHTS for the non-turbo compatible with the Turbo? Also how much room for error does the CHTS allow for in OHMing it?
I've swapped turbo & na head temp sensors before.... they worked the same.
Cool, thanks for the info. I'm gonna swap around the CHTS sensors from my N/A to Turbo and see if that makes any difference.
oh good. I did the same because my NA had a fairly new one, but it made no difference. My car still runs like crap. I'm getting very frustrated with this junk engine...
so true... stupid 25 yr old electronics. I almost think the wiring harness could be bad. That's my last thing to change out.
Maybe if I do the Z31 ECU swap, I'll just swap in the Z31 wiring harness too. I think that is one method of the swap, correct? |
Quite a bit more work, but yes, fresher/updated wires.
Ok, so I OHMed my Turbo Z and I was getting a reading of 1.9 from the CHTS. The garage door had been open for a few hours, but it felt slightly warmer in the garage and I was getting a reading of 2.1 OHMs. I'm thinking maybe the CHTS is just off by a little on the turbo. It's really hard to figure out. I was thinking I should get an A/F gauge like Nismopick has said, but then it occured to me that if the O2 sensor doesn't work until a certain temperature that the A/F gauge would be of no use to me because generally by the time the O2 would be working the car's running fine.
Maybe if I do the Z31 ECU swap, I'll just swap in the Z31 wiring harness too. I think that is one method of the swap, correct? With some time and a little elbow grease, you could do it. If you're careful, you could re-use the connectors as well. How much time do you have...?:armata_PDT_03: |
Maybe if I do the Z31 ECU swap, I'll just swap in the Z31 wiring harness too. I think that is one method of the swap, correct? Rod |
How much coolant would need to be drained to pull out my CHTS or should I just drain it all?
Yeah I found this out after I drained the coolant from my 2+2. Another thing that goes to show this Haynes guide isn't exactly accurate. It's too bad they didn't wait until 1983. In the Haynes guide they give info to remove Water/Cylinder Head Temp Sensors. It says you need to drain coolant. I noticed the CHTS that came from my 2+2 was not wet at all, and I didn't have containers so I could drain the coolant and reuse it from my Turbo Z. So I started undoing the Turbo Z's CHTS to find no coolant came out. Then I realized Haynes was again not to helpful when it comes to the 82-83 Zs. |
sorry to thread hijack here, but is your maf ok(dirty?)? what is your engine doing exactly? |
boost leak at the base of the injectors. I changed to a different style of injector holder. All fixed.
I changed the fuel pump in my car without draining the tank. :D The main fuel feed line poured out fuel for that brief moment when I moved it from one pump to the next. :D |
I just held my mouth under the line so I wouldn't get the extra fuel on the garage floor. It was only about 1/4 cup of gas.
| All times are GMT -7. The time now is 12:45 AM. |
