Charging issue?
Old Jun 23, 2014 | 06:35 AM
Pipsqueak's Avatar
Charging issue?
Car is 80 n/a
I recently replaced my Combination Meter (bad speedo). A few days after replacing it, the top right light of the three lights on the side started to flash (does not stay on solid only flashes). It says "Charging'.
Looking at the fsm el-35 that light should be the "light and key warning lamp", and the charging indicator is on the combination gauge.
The charging indicator on the gauge does not indicate a issue.
I'm not sure what is going on with this.
Everything else on the cluster works fine, and this did not light up when I first installed the cluster.
Is this a case of getting a cluster from a different year model, or do I have problem i need to resolve?
Any suggestions are welcome.
Old Jun 23, 2014 | 06:37 AM
If just the speedometer was bad, why didn't you just swap speedometers and keep the orig cluster?
Old Jun 23, 2014 | 07:00 AM
Pipsqueak's Avatar
1 Never thought of that. to swap out the speedo, is it just a few screws, or is there more involved?
Old Jun 23, 2014 | 07:17 AM
You have to open up the cluster and swap speedometer units. Takes about 5 extra minutes and requires a phillips screwdriver.
Old Jun 23, 2014 | 10:10 AM
Pipsqueak's Avatar
Looks like I fond someing to do this weekend. Thanks.
Pipsqueak
Apr 24, 2012 09:49 AM
CWHammer
Sep 2, 2010 04:30 PM
jk11blueboi
Jan 26, 2010 01:08 PM
SHADY280
Sep 22, 2006 08:08 AM
fairladyVT
Mar 21, 2005 12:04 PM
