the chane wont go back on ???????
Old Feb 25, 2005 | 09:01 PM
81 Black L28E's Avatar
WHAT DO I DO HELP PLEASE
Old Feb 25, 2005 | 09:25 PM
icice9's Avatar
Super Siver & Black Stud
ummm before ou took off the cam sprocket .. did you use a wedge to keep the chain tensioner compressed cuz if you didnt.. you might have just ****ed yourself.... well not really. you just have a lot more work ahead of you...
Old Feb 25, 2005 | 09:41 PM
its to tight like less the an 1/8 of an inch i got it all back together after my head gasket came today and it wouldnt start ........... it sounded like it was a tooth off and i thought that because because when i was putting it ..back together it looked off so i pulled it apart and when i did that ...........the chane droped i think becauce it wont go back on .
WHAT DO I HAVE TO DO NEXT................ I have to move monday i need this car
Old Feb 26, 2005 | 12:23 PM
The chain tensioner popped out a little (or all the way and is lodged against the curved chain guide)
You HAVE to pull the balancer (by hand, I've done it that way 5 times!) and front cover. You can have it off, chain on properly and back together in 3-4 hours.
As long as you get the oil pump installed on the correct tooth, you should be off and running assuming you didn't screw something up with the head gasket. But I can't say....
Old Feb 26, 2005 | 09:20 PM
THE LOWER END WAS MOST DEFF AT TOP DEAD I CANT SAY THE SAME ABOUT THE CAM SIDE THE OIL PUMP IS DEFF ON THE RIGHT WAY I AM SURE OF THIS
MO3IUSONE
51
Dec 19, 2016 03:22 PM
ZXT83
Jul 21, 2009 01:15 AM
tyyr
Apr 6, 2005 07:39 PM
85_2fast4u
Jul 9, 2002 09:37 PM
Darrel
Jun 15, 2001 06:14 PM
