can anyone with a 280zx tell me this...
Old Dec 1, 2002 | 10:09 PM
Re: can anyone with a 280zx tell me this...
yes, they should all work. The position right before cranking (after you crank, it is spring loaded to go back to this position) is the ON position. Everything should have power there. That is the position you keep it in while you drive. Right before that is Accesory position wich lets you use the radio. Before that is Off, and then turned way down is the Lock position which engauges that little steering wheel lock.
In your engine compartment on the front right side, there is a plastic box. Snap off the cover and it should have about 6 relays inside that you can unplug. Pull two out and swap them. Turn the key around and see if there was any change. If not, swap the same two back and try another two. Do this untill you have found the bad relay. That may or may not be the correct relay though. There are others hidden in various locations behind the dash.
