Brakes
Old Oct 30, 2007 | 12:30 PM
plainwhiteZ's Avatar
Brakes
I needed new pads all around and had a caliper that wea sticking on the rear driver side. I bought the parts and took it to a shop when I got the car back the pedal was lower then before with the old pads (there was about an inch more of play). I took it back to the shop and watched them re-bleed the brakes and checked my fluid, everything was in order but the pedal was still low, becoming very near to the level of my gas pedal.
The car still stops, but the low pedal makes me a little nervous. If you pressed the brakes hard enough you could step on the gas accidently pretty easily.
any Ideas?
Old Oct 30, 2007 | 12:32 PM
Did you ask the shop if they adjusted the pedal height?
Old Oct 30, 2007 | 01:30 PM
your rear calipers may not be self-adjusting. You need a working parking brake cable that pulls and returns properly to get them to adjust in.
Is your parking brake cable hooked up?
Does it work good?
Old Oct 31, 2007 | 01:41 PM
yeah, parking brake works fine. I asked my dad to take it back to the shop so I was not present the second time. It was a little mexican shop ( I'm mexican, not hatin') and the owner didn't speak a lot of English.
dont know if it makes a difference but I only had one rear caliper replaced.
ddatsun
22
Nov 9, 2007 08:47 AM
Smittyz33
Mar 21, 2006 11:33 AM
Fast240Z
Other Cars
Dec 1, 2005 12:35 PM
S1j9m85
May 15, 2004 10:48 AM
Al Dukes
Oct 11, 2003 01:23 PM
