Body welding question
Old Apr 6, 2014 | 09:21 AM
Lesnocker's Avatar
I'm starting the t-top again since its not deadly to be outside finnally. Now what put me out last fall was a seam let go between the floor pan and inner rocker. This is a perfect 1/16 gap from the trunk release to the ecu. Could I simply stitch weld the seam back in. Or should I metal brake a 90° peice of patch and grab the inner rocker and pan with some 1/8 plug welds?
Old Apr 6, 2014 | 05:26 PM
I always overbuild... so I suggest using angle-iron.
Old Apr 6, 2014 | 05:46 PM
Lesnocker's Avatar
In our neck of the woods we call that hillbilly pinch welds. Still up in the air trying to find a good brand of stripper. Like to get the under side stripped and patch up the lil spots. May need a new welder my flux-core makes such a dam mess. My buddy got that walnut blasting crap for a fiberglass car. Not sure if it got enough *** to cut thru "Rusty Jones" undercoating though. Plus what a mess!!
Old Apr 6, 2014 | 10:40 PM
Oh and btw the Highlander quote is "I have something to say - It's better to burn OUT than to fade away".....
Old Apr 9, 2014 | 05:25 AM
Lesnocker's Avatar
Highlander Kurgan Church Scene - I Have Something To Say - YouTube
Kudos someone else remembers the 80s. Naw just a play on words during my head-gasket failure. Didnt think anyone would catch it so your the winner!!!
Anyway I looked into "Klean strip" Aircraft paint stripper. Last time I did stripper I got the 5.00 napa crap and all it did was make a agitating slime that burnt like hell. Ol Rusty did a hell of a job I tried a sample with a puddy knife and that undercoat is thick.
Old Apr 10, 2014 | 03:12 PM
to get rid of the undercoat i find a propane torch and a wood chisel sharpened constantly to work very well. to rid myself of rust i use a twisted braided wire brush on a grinder and then just a cookie on a die grinder works well. to get in the corners and such i use a handheld spot blaster with silica as walnuts aren't as good for rust, more for gently removing paint.
Old Apr 10, 2014 | 04:18 PM
PredatorZ's Avatar
Aircraft stripper
I have some of that and it works really well, its thick enough you can brush it on and it sticks pretty good, watch out getting it on anything nice, I had a headlight bucket on a towel on our brand new washing machine, soaked through and took the enamel right off.
BlueKitsune
Jan 3, 2014 11:17 PM
JoeGasm
15
Dec 19, 2008 01:00 PM
speed280zx
Oct 17, 2008 05:51 AM
duowing
May 16, 2007 01:12 PM
y2ktranny
Jun 10, 2004 09:58 AM
