Best way to test injectors?
Old May 28, 2010 | 02:18 PM
BlueKitsune's Avatar
Intrawebz Wizard
Whats the best way to test the injectors to make sure their working 100% aka not leaking, not clogged, and still spray right?
PS: Nismopick, Ya Your right about carbs.
Old May 28, 2010 | 02:41 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
Giving up already?
Old May 28, 2010 | 02:45 PM
Intrawebz Wizard
Originally Posted by audiofreak97
Giving up already?
Yep. I decided its not worth the work anymore. I'm gonna either repair the stock EFI or mod up a Z31 N/A efi into it. Either or I don't know yet.
Old May 28, 2010 | 03:22 PM
Dude, you got to have some patience. Look at me. I blew up 2 Z cars, in one weekend. I fried the head on one, on a Thursday. Then blew the head gasket, on the other one, on Sunday. I still am without a running Z. I am currently, working on taking the head off. And take it down to the machine shop. When I get working again.
If you really want carbs in your Z. You should not give up so easily. If you are throwing in the towel. And wanting to convert back to EFI. You never really wanted carbs in the first place. That is how I look at it. Just giving you some friendly advice. Do what you think, is where you want it to be. Good luck
Old May 28, 2010 | 03:57 PM
Intrawebz Wizard
Well the issue is is that I need a car now and the SUs decided to throw up a problem I cant fix myself (I think) I tinkered with the carbs for at lest i don't know 8 hours or more just trying to get them set right. and they just wont hold a tune even tho EVERYTHING is cleaned and spotless and adjusted right even down to getting the fuel levels to the 23mm they need to be and they STILL wont run right.
Old May 29, 2010 | 10:20 PM
Intrawebz Wizard
Ok I'm gonna say that I take a T connector and a bunch of fuel lines and I hook it all to an EFI pump with a EFI regulator and shock the injector with a 9volt battery with the right polarity. How about that?
Old May 30, 2010 | 10:51 PM
Intrawebz Wizard
Huh I've been wondering. whats the diff between the different colored injectors? I notice Green brown and black so far. Anyone know?
Old Jun 1, 2010 | 11:03 AM
Intrawebz Wizard
Ok I have 3 green injectors 3 pink injectors and 1 black injector. Which one does what!? Are they different CCs? Or what?
Old Jun 2, 2010 | 09:49 PM
Niku-Sama's Avatar
eff good grammar
probably not a good idea, i've also been told theres no real polarity on these but once they start working hooked up one way and you switch the way the current runs it can cuase them to not work.
9v battery may not be the same ammount of voltage in the car but it could be more amps or some other value and kill them
[2nd injector color post]
you'll have to search it, i've only found green injectors off of datsuns but at the same time i've only been searching for N/A injectors. pink is familiar. mabe supra injectors? black i have no clue
its strange because i have found the same greens in volvos subarus toyotas and mazdas. also green tops in I6 maximas are the same as green tops in I6 280s despite the displacement difference
Old Jun 2, 2010 | 09:58 PM
Intrawebz Wizard
The 9 volt bat worked fine. And YES the polarity matters BIG TIME and I now have 6 great injectors that dont leak and have a goos spray lol
And I've searched and searched and found nothing. the pink ones have the datsun/nissan shape emblem on the while the greens dont.
Old Jun 2, 2010 | 10:20 PM
^ The green ones, could be Beck/Arnley's. Mine are black with the green injector plug. Is that what they look like? If so, real good injectors, best you can get.
Old Jun 2, 2010 | 10:46 PM
Intrawebz Wizard
Ya their black bodies and green caps/connector. I noticed they do spray better then the old pink ones by far but the pink ones did their job good enough to pass lol.
Injector testing kit lol
Old Jun 3, 2010 | 03:18 PM
Niku-Sama's Avatar
eff good grammar
mine are factory installed and they are green topped they may be from beck but they are probally remans so they will most likely look the same.
and polarity doesent matter, i've hooked them up both ways and they spray, you run the risk of them not working ater a while when you switch it part way though its life.
your also using a 9volt battery to and the signal is going to be slightly different comming down the wire in the car
Old Jun 3, 2010 | 03:21 PM
Intrawebz Wizard
You really picky for someone that says it doesnt matter what polarity it is. Either way my setup worked and I tested then injectors just fine and their not burned up. Trust me when I say a car battery has more juice then a 9volt.
Old Jun 3, 2010 | 04:44 PM
Hmm..interesting. I believe the original ones on my slicktop, were a brown color. But maybe green ones are just remans, from an auto parts store.
Old Jun 3, 2010 | 10:35 PM
Intrawebz Wizard
I've seen so many different colors that its confusing... Pink Brown Green black white.... I think as long as the ohm and CC is the same you'd be fine. all of mine read the same ohm (once I cleaned the contacts)
Old Oct 13, 2010 | 12:16 AM
borini63's Avatar
Brown for Turbo
Green for N/A
I am not sure about the pink and the blacks.
Old Oct 13, 2010 | 02:34 PM
nitrojunkie's Avatar
Look at this for a DIY test rig.
http://www.ecs.fullerton.edu/~sowell...torTestRig.pdf
Old Oct 13, 2010 | 03:57 PM
Intrawebz Wizard
I like that rig! I wish I new about that when I tested my injectors lol
PowerhungryBill
Jan 20, 2009 07:09 PM
thetremendousti
Aug 14, 2008 09:42 PM
zfreakracing
22
Feb 17, 2004 06:33 PM
